love the color match! Sorry about the damage. I say keep the stock front and just fix her up.
Hey guys, what camber should I run in the rear to tuck the tires away nicely? Wheels are Apollos 19x9.5 +20. Fenders are rolled. I currently run -0.5 camber. Going to lower the car about 3 inches total. I do want the tires to last for a couple of seasons. Same question from the front. 19x8.5 +20 on the front. Tires are 225/35/19 FR and 245/35/19 RR. Thanks for the help
CandlestickPark
ill Sedan
close
- Join DateJun 2007
- LocationLong Beach, SoCal
iTrader Positive Feedback100
iTrader Feedback Score(87)
Liked:2,688 Times in 1,449 Posts
Quote:
Camber out back will be about -2.5 to -3 with a 245/35 depending on how flat your fenders are rolled. Up front you'll be fine with natural camber. You can either run a 5mm spacer to be +15 up front or run a 235/35 tire (and no spacer).Originally Posted by lox1985
Lox, you could easily run a 10mm spacer up front to be +10. I am runing 225/40/19s w/ those offsets and natural camber with have no issues at all. Toe in spec.
When you say "natural" camber, are you implying that I don't need front camber arms to adjust the camber at all since it will not be too bad to kill the tires at 3 in drop?
CandlestickPark
ill Sedan
close
- Join DateJun 2007
^Kind of. Yes natural camber meaning the camber introduced by a 3" drop. But no to that amount of camber not being too bad to kill the tires. You won't need front upper arms to clear the fender, but if you want to bring it to be more positive then yes you'll need front upper arms.
Quote:
i saw it. and brew hahaOriginally Posted by CandlestickPark
In for pics of Cliff's (dznuts) ride at IA this past weekend. He said he was going to be changing the color of the faces on his wheels, curious what he ended up going with.
Quote:
Then I wasn't feeling the teal. And color matched them Thursday night before we leave Friday morning.
And then a retread whipped my a$$!
bumper,lip,all grills,one wheel,side shirt!!!!
I Really Dig the blue (teal) color goes well with the white. Go with a kurrokie front and fix the old lip and bumper so in the any event this happens again you have a good back up! CAR IS SICK THO!!Originally Posted by dz n.u.t.z.
Well I painted them Tiffany's last Friday.
Cliff can't run the KuRookie, at his height it'll touch the ground while parked.
hence why I no longer have a kurookie.
dz n.u.t.z. - found two pictures of you on H-T from the Import Alliance meet.. looked good! Sorry to hear about the tire on the freeway
