OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Sep 20, 2011 | 03:13 PM
  #4531
iiiiiekoiiiii's Avatar
Rears are 10.5 +18 with a 245/35. Fenders are pulled slightly (5mm).
My rears are maxed out on one side and I have a few threads on the other side (my car is just weird that way...LOL)
Its not weird, Im the same way lol.
Driver side rear sits lower then passenger so If I max out the passenger rear gotta leave few threads on the driverside.
i dont think i pulled my fenders much, but i rolled them flat.
Old Sep 20, 2011 | 03:16 PM
  #4532
CandlestickPark's Avatar
ill Sedan
I was just looking at your old setup I'm surprised you aren't running more camber out back with a 10.5+17 and a 255/35 with only a fender roll. I'm lower than you are in this photo but still I would expect more camber out back.
Old Sep 20, 2011 | 04:31 PM
  #4533
4DGS's Avatar
Do you know the camber though?
The sedan hides camber like crazy.
-4.7 and -3.7 lol
Old Sep 20, 2011 | 04:33 PM
  #4534
ill Sedan
Nah I don't know what his camber was at in that pic, maybe he'll chime in.
Agreed, I'm at -3 up front and it looks like I'm hardly running any at all...haha.
Old Sep 20, 2011 | 04:56 PM
  #4535
yea lol. that pix was before I maxed out the rears. And when I first lowered it on them evenly on both sides.. Passenger rear sat higher. From that same day I have pix from driver side which sat lower.
From sitting higher I guess doesnt show camber much.
I have No idea What my rear camber #s are, Its all natural camber from the drop.
I should be installing my camber kit soon.
Old Sep 20, 2011 | 05:03 PM
  #4536
You can see the Uneven rear camber.
I hope my camber kit fixes it.
Cause now on 20s im sitting alot closer to the fenders.
20x10.5 +25 with 275/30/20 nankangs
Driver side takes a key. passenger side credit card. But it does hit the tire, I can hear it lol
Old Sep 20, 2011 | 05:08 PM
  #4537
ill Sedan
If its natural camber from your drop its probably in the neighborhood of -3ish, that's my natural camber up front (I don't have aftermarket A-arms).
Old Sep 20, 2011 | 05:11 PM
  #4538
4DGS's Avatar
Every inch is roughly a degree of camber, but it differs on some cars oddly enough.
Like I don't even have any aftermarket camber adjustment lol
Old Sep 20, 2011 | 05:13 PM
  #4539
Matzo Ball's Avatar
eko, what tires are you running in the front? If I went w/ 20s, I was thinking about 225/35 front and 255/30 rear.
Old Sep 20, 2011 | 05:15 PM
  #4540
Matzo Ball's Avatar
actually, its more like 5-10mm per every degree of camber if you are on 19s. Would be closer to 7-12mm on 20s.
  #4541
Yup stock a arm. Should be -4 on driverside rear passenger gotta be -3 big difference btwn them eye can tell
Old Sep 20, 2011 | 05:21 PM
  #4542
ill Sedan
Blain is referring to ride height I believe whereas you are referencing offset. Both of you are correct from what I understand.
Its closer to 5mm than 10mm, for every degree of camber.
Old Sep 20, 2011 | 07:12 PM
  #4543
Im runnin 245/35 on 9 now. No stretch.
245/275
Only difference I have from most is, its X, so awd sat higher then rwd stock...
But im on coils. dont know if it'll still effect it cause, Im bringing the body to the same low from higher travel...
Old Sep 20, 2011 | 10:28 PM
  #4544
Matzo Ball's Avatar
I have an X as well on BCs so I hear ya.
Old Sep 23, 2011 | 03:13 AM
  #4545
you had asked me for a side shot. i remembered today. lol
i will get spacers for the fronts soon.
sorry about the open trunk n hood, Just changed out my destroyed axle.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
