OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jan 4, 2012 | 10:50 PM
  #5011
NjMatteSedan's Avatar
Originally Posted by iiiiiekoiiiii
i suggest u get rid of the wheels and get new wheels with correct offsets for fitment.
He cant afford hew whes ATM. Theyre the same wheels stoof had on his sedan
Old Jan 5, 2012 | 01:26 AM
  #5012
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by miguelwv
Hey guys im lookong to see if some of you guys can help me out here..i have rims 20x8.5 +35 front 20x10 +40 rear ..what do ya suggest is good size tires n spacer size for a nice setup. Sitting on bc coils
How low are you dropped?
Old Jan 5, 2012 | 02:42 PM
  #5013
JosansG35's Avatar
You can put a 30mm spacer up front and may be a 25mm in the back.
Old Jan 7, 2012 | 04:51 AM
  #5014
Gorg3ou5's Avatar
ROLL SO HARD, THAT SHI* SCRAPE!
Old Jan 7, 2012 | 05:31 AM
  #5015
JosansG35's Avatar
^Amen to that
Old Jan 8, 2012 | 10:30 PM
  #5016
iamtimshady's Avatar
Originally Posted by iamtimshady
I need to get get new tires tomorrow! Should I stick with the sizes I have or switch it up?
Current setup:
Front 19 x 8.5 +38 245.35.19 - General Exclaims UHP
Rear 19 x 9.5 +42 275.30.19 - General Exclaims UHP
Sitting low & am going 1/2" lower, Pics on page 4: https://g35driver.com/forums/media-s...ore-low-4.html . Installing a rear camber kit and getting an alignment as well. Also installing spacers (in the front at least, possibly the rear).
Appreciate the help
I went with 235/35/19 for the fronts; Nexen n3000, the only thing close to that size in stock.
I installed my SPC rear camber arms and toe bolts tonight so I need to get new rears in the next couple days and get everything aligned.
What size rears should I get and what size spacers do I need for the fronts. Any for the rear? I'm sitting @ 24" to fender. Rolled pretty flat.
Appreciate it.
Old Jan 8, 2012 | 10:52 PM
  #5017
miguelwv's Avatar
Thanxz eko yea i kno hopefully next year but for i now i have to stick with these :/
Old Jan 8, 2012 | 10:53 PM
  #5018
miguelwv's Avatar
will do thanxs
Old Jan 8, 2012 | 10:55 PM
  #5019
miguelwv's Avatar
well im on tein s springs now but going to get bc coils soon and slamming it
Old Jan 8, 2012 | 11:47 PM
  #5020
hawaiinpunch's Avatar
Originally Posted by gorg3ou5
roll so hard, that shi* scrape!
roll hard! Park harder!
Old Jan 9, 2012 | 11:50 PM
  #5021
If you're going to slam it then you'll need spacers to flush the wheels out. Do you want to stretch the tires or no?
Old Jan 10, 2012 | 09:18 AM
  #5022
miguelwv's Avatar
yes what size spacers and tires do you recommend?
Old Jan 10, 2012 | 09:40 AM
  #5023
P10 WRC's Avatar
Question for all you slammed guys. Are you able to turn the steering wheel all the way from side to side or are you limited now because the tire hits the fender? I installed some coils and want to go a bit lower in the front, but the fender is almost sitting on the tire are full lock of the steering wheel. It seems that if i go any lower i will not be able to turn the wheel all the way
Here is a pic of what i am talking about
Old Jan 10, 2012 | 11:28 AM
  #5024
JaE35's Avatar
Moderator
G35 Sedan
I'm sure everyone will say smaller tires with more stretch
Old Jan 10, 2012 | 11:51 AM
  #5025
CandlestickPark's Avatar
ill Sedan
^Exactly what I was going to say. I can turn at full lock, but I'll rub. And if the ground is uneven I better do it slowly otherwise I'll jack up my fender. Also you are going to have to be very careful coming out of driveways with the wheel turned as your fender may buckle.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
