OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jan 22, 2012 | 02:10 AM
  #5071
SN00P's Avatar
CLUB MODERATOR
Thanks brother ^^! Yes ITS DG
Old Jan 23, 2012 | 11:42 AM
  #5072
P10 WRC's Avatar
hey guys, i am going to get my front fenders pinched flat and have a question. The place i called (UMS Tuning) said that their rolling tool cannot pinch it flat. Is there something specific i should be asking for? Was he correct in saying that an eastwood fender roller will not be able to do this?
here is the pic of the roller they use
OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan-ushhx.jpg
Old Jan 23, 2012 | 11:58 AM
  #5073
SN00P's Avatar
CLUB MODERATOR
What you use is a Eastwood fender pincher.
The front fender are thin. It you roll them they could pull your fenders if not done perfect ..
They are about 50-60 from amazon.com. cheaper to buy it and do it yourself. Its very simple
Old Jan 23, 2012 | 12:11 PM
  #5074
P10 WRC's Avatar
is this it? I need to order asap to get this done by friday
Amazon Amazon
what are the procedures? anyone i can speak to that has done this before?
I also see this one with a heat gun
Amazon Amazon
Here is a video, but it looks like this guy is doing it wrong
Old Jan 23, 2012 | 01:13 PM
  #5075
Matzo Ball's Avatar
Originally Posted by iamtimshady
So I went to get my car aligned for the first time since lowering it. I told the tech to set the toe to zero (which he got close, fronts @ 0.05, rears @ 0.1X, rears were 0.68). I had about a 5mm gap between the new slimmer tires and fenders so I asked him to add just a tiny little positive camber to get them closer.
I get home and my rear looks way higher than it did so I measure it.... It jacked it up an inch!? I check the spec sheet and rear camber went from -3.9* to -1.6*!? Would that affect the height an inch? Should I take it back to the shop and have them change it back? Or can I adjust the camber arms only without affecting the toe?
Should I have left the camber @ -4* and just added 5mm spacers?
Correct. If you add back camber, it will raise the overall height of your car. Just adjust your coils and go lower.
Old Jan 23, 2012 | 02:54 PM
  #5076
CandlestickPark's Avatar
ill Sedan
http://www.amazon.com/gp/cart/view.html/ref=gno_cart
http://www.amazon.com/Eastwood-Fende...ecc_rvi_cart_2
http://www.youtube.com/watch?v=3v_Kd...layer_embedded
Yes that is the tool: http://www.eastwood.com/fender-finisher-1.html
Remove the screws in the fender well and clean the inside of the fender to remove any debris/dirt.
Heat up the fender and pinch flat (just the fender not the fender liner) .
Old Jan 23, 2012 | 04:03 PM
  #5077
P10 WRC's Avatar
cool, that is the one i ordered. I don't think it will be here in time though for this weekends show
Old Jan 25, 2012 | 12:32 AM
  #5078
Fr3shIngredient's Avatar
is anyone running a 18x10.5 all around setup? i want to run 18x10.5 all around but what offsets and tire size should i get. I've looked at 4DGS sedan and it looks sick but im gonna pick up some varrstoens and they dont have 11.5.
Old Jan 25, 2012 | 01:36 AM
  #5079
Gdup35sedan's Avatar
ENVautoDetailing.com
10.5 +22 would be nice with a 235/40 all around
Old Jan 25, 2012 | 01:47 AM
  #5080
would the front fit without rubbing though? i seen your pic with the xxr and its 18x10 and the front looks like it doesnt have any space left.
Old Jan 25, 2012 | 10:38 AM
  #5081
P10 WRC's Avatar
Test fitted my 20mm spacer last night. Still have a bit more low to go if i want to. sorry for the crappy iphone pic
19x9 +11
Old Jan 25, 2012 | 10:44 AM
  #5082
ill Sedan
What tire size are you running up front? Looks like maybe a 235
Old Jan 25, 2012 | 10:55 AM
  #5083
P10 WRC's Avatar
225/40 It's a tall tire which is why it looks so big. I will be going to a 225/35 when these wear out.
Old Jan 25, 2012 | 11:07 AM
  #5084
ill Sedan
OK, photo is dark so I can't see how close the tire is to the fender. If its close and rubbing badly I would hold off on adding the large spacer until you get a smaller tire size, would hate for you to jack up your fender.
Old Jan 25, 2012 | 11:23 AM
  #5085
P10 WRC's Avatar
it's not rubbing at all at full lock.. the only thing i have to worry about is turning and bumps or dips. anything more then a 1/2 turn of the wheel and a bump will rub. I have the car raised up a bit now until the show this weekend to be safe though. at full lock there is about 2mm's clearance from the top of the tire and the fender
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
