OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jun 27, 2012 | 07:17 PM
  #5776
Gdup35sedan's Avatar
ENVautoDetailing.com
I'm currently at 9.5 +7 with a 235/35/19 up front and I rub all day long, nothing too crazy, but still rubs.
My motto: if it doesn't rub it doesn't fit
Old Jun 27, 2012 | 07:19 PM
  #5777
JosansG35's Avatar
Originally Posted by 4DGS
^ no 10.5 +17 out back
Josan, yes. My rear specs are 11.5 +16
You'll either need A arms or a front pull.
I'm gonna drop my front some more so I can clear it. I'm gonna run 11 0 in the back so I think I'm gonna run a 235/35, You have any pics of stretch of a 235/35 on an 11 or 245/35?
  #5778
CandlestickPark's Avatar
ill Sedan
Same here I rub when I turn on flat ground.
I'll add to your motto: If it doesn't rub it doesn't fit, or you aren't low enough.
Old Jun 27, 2012 | 07:21 PM
  #5779
ill Sedan
Currently Active Users Viewing This Thread: 15 (9 members and 6 guests)
CandlestickPark, 4DGS+, DTRUONG_112, Gdup35sedan+, JaE35, JosansG35+, MPG35fiend+, P10 WRC, The Stimulation+
Many of the Sedan fitment gurus are present....holla!
Old Jun 27, 2012 | 08:33 PM
  #5780
MPG35fiend's Avatar
excluding me... lol.
but how'd you do that?^
Old Jun 27, 2012 | 08:39 PM
  #5781
The Stimulation's Avatar
I have a 9.5 +5 on a 225/35/19 and I don't have any room to go more aggressive (not without adding more camber). Fenders pinched flat and flared from rubbing. My tires run on the larger side of true so I bet that is the difference.
Gotta be the difference. Kinda sad to be mentioning this but I put on Yokohama 225/50's a 7.5 and I can't use them for my rear (with 38mm spacer) because they run larger than the Sumitomo's I have. With the Sumitomo's I have slight rubbing and only needing half a degree of camber adjustment and with the Yoko's I would need at least a degree more than that. Another thing I noticed when I bought tires other than Hankook, is the sidewall shape. I like how the Hankook was sharp and had a nice round curve to it whereas the Achilles were fully rounded and would have more chances of rubbing.
Old Jun 27, 2012 | 08:44 PM
  #5782
235/35 on an 11 you say?
Hankook's:
Old Jun 27, 2012 | 08:52 PM
  #5783
ill Sedan
Magic....
Not really. People viewing this thread are listed at the bottom of the thread.
Old Jun 27, 2012 | 08:56 PM
  #5784
MPG35fiend's Avatar
Magic....
OHH!!! LMAO. I'm still a freaking NEWB... que pena.
Old Jun 27, 2012 | 10:34 PM
  #5785
JosansG35's Avatar
235/35 on an 11 looks like a good amount of stretch, and I'm gonna need it!
Old Jun 27, 2012 | 10:54 PM
  #5786
DTRUONG_112's Avatar
Nice to see all the setups and advice guys. I'll have to go more aggressive for the next set.
Still needing answer though, how much camber can be achieved with stock upper arms and rear arms? Is there a need to purchase aftermarket arms if I never plan on going oni camber?
Old Jun 27, 2012 | 11:13 PM
  #5787
4DGS's Avatar
That barely looks stretched at all Blain, what brand tires? Will look that much more gangsta with a 225 and more poke.
Nankangs, they were still a pretty fair stretch, but the tires were intended for 10.5s...
You plan to run 11 +0? What's your plan for the fenders? Or are you cambering it the whole way?
Yes, buy rears.
Old Jun 27, 2012 | 11:27 PM
  #5788
MPG35fiend's Avatar
i have to ask...
HOW MANY OF YOU HELLA FLUSH GUYS RUNNING FRONT CONTROL ARM CAMBER KITS???
man I'm starting to regret getting my SPC front camber kit since i don't believe any of you guys have them on Aggressive set ups....
Old Jun 27, 2012 | 11:31 PM
  #5789
ill Sedan
i have to ask...
You will only need a front camber kit if you need to dial in positive camber to make your setup poke and bring the tire closer back to the fender
OR
you are running a very aggressive setup which requires more camber than the natural camber that being slammed gives you.
You could always do a fender pull/flare up front within reason and get away with not need to add negative camber.
Old Jun 27, 2012 | 11:35 PM
  #5790
Ummm, can't recall how much negative camber I had with stock upper A arms but it's at least -3. In the rear I think around -4 before toe is unable to be set to 0. You can still go a little more and be in spec with the toe.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
