OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jan 6, 2013 | 10:17 PM
  #6616
Drew113's Avatar
Ban Hammer Expert
Mexiflush
Old Jan 6, 2013 | 10:35 PM
  #6617
JaE35's Avatar
Moderator
G35 Sedan
Do you not have a camber kit?
Old Jan 6, 2013 | 10:38 PM
  #6618
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by ven377
is this aggressive or poke? or what?
ignore the fenders :P
I call it unfunctional and just plain dumb.
  #6619
CandlestickPark's Avatar
ill Sedan
Its aggressive but not stretched. Lets stay on topic.
Old Jan 6, 2013 | 10:50 PM
  #6620
ven377's Avatar
it is stretched
im not planning on doing any negative camber
getting some coil overs next week
i can run camber and look like everyone else /-\ but im shaping out the fenders once i lower it
Old Jan 6, 2013 | 10:57 PM
  #6621
ill Sedan
OK, well its not enough stretch for the amount of camber you are running right now. But given that you still have much more work to do we'll standby for progress pics...
Old Jan 6, 2013 | 11:05 PM
  #6622
ven377's Avatar
what tires would you run on a 20x11 255, 245?
Old Jan 6, 2013 | 11:07 PM
  #6623
ill Sedan
Depends on the offset but I would lean towards a 245 that ran true (or on the larger side of true). Right now I have a 245 on a 10.5 with Yokohama S-Drives (they run true) and its a nice stretch, nothing extreme.
Old Jan 6, 2013 | 11:48 PM
  #6624
ven377's Avatar
a nice stretch on 10.5
so to have around the same stretch on a 11 would be 255
not a whole lot of difference between 255 and 265
i look around and lots of people had 275 and said it was a good stretch thats why i went with 265
i should of done 265 30
Old Jan 6, 2013 | 11:56 PM
  #6625
ill Sedan
I said a 245 because I figured if I had 11s I would be more aggressive than I am now other wise I would have to worry about inner clearance issues so I would need more stretch. Of course I don't have as much fender work as you so given that you are going to do fender work you can go with any size you choose really and just pull to make everything clear. And a 255 should be about the same on an 11 as a 245 is on a 10.5.
Old Jan 7, 2013 | 12:04 AM
  #6626
ven377's Avatar
what is the offset on your wheels?
i like the rim poke so i might have to get some 245s
im just worried about getting a leak and losing air from pot holes or speed bumps from to much stretch
Old Jan 7, 2013 | 12:50 AM
  #6627
gtrefever's Avatar
I ran a 245 on a 11. Nice stretch
Old Jan 7, 2013 | 03:31 PM
  #6628
JosansG35's Avatar
This is how a 245/35 looks on an 11
Old Jan 7, 2013 | 06:16 PM
  #6629
The Stimulation's Avatar
Only that will happen is if you run a 245/30. I tried to fit it on but couldn't. Perhaps a true sized tire would have worked. I used Achilles. Stretched better but still had a gap. 245/35 you'd have no problem. Especially since I ran a 235/35 on an 11 with no issues.
Old Jan 7, 2013 | 06:51 PM
  #6630
ven377's Avatar
alright ima start looking for some 245s
thanks for the info
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
