OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Jun 22, 2010 | 08:34 PM
  #916
Quote: i have a 8.5 and 9.5 and i think I'm going to go with 215/35 and 225/35 for mine ... i think that should be a good stretch
If you are going to stretch that much you are going to need low offsets to make it flush. Negative for the fronts, single digits for the rear.
Reply 0
Jun 22, 2010 | 08:52 PM
  #917
thx everyone! heres a side-ish pic
Reply 0
Jun 22, 2010 | 08:58 PM
  #918
duuude that looks awesome
Reply 0
Jun 22, 2010 | 09:10 PM
  #919
Baws!.. i like the choice of wheel
Reply 0
Jun 22, 2010 | 10:30 PM
  #920
still need to go moar lower
Reply 0
Jun 22, 2010 | 10:49 PM
  #921
Doggy door and roof rack...nice!
Wheel/tire specs?
Reply 0
Jun 22, 2010 | 11:07 PM
  #922
them tires look meaty, CCW wheels?
Reply 0
Jun 23, 2010 | 12:13 AM
  #923
I really like the drop.
Reply 0
Jun 23, 2010 | 12:19 AM
  #924
rear looks good.. front needs tons moar low!
Reply 0
Jun 23, 2010 | 12:21 AM
  #925
I am going to say they look like linea corse bbs lm reps
Reply 0
Jun 27, 2010 | 12:14 AM
  #926
With my sony pns
Reply 0
Jun 27, 2010 | 08:19 AM
  #927
Quote: If you are going to stretch that much you are going to need low offsets to make it flush. Negative for the fronts, single digits for the rear.
ok then what would be a mild stretch so i wouldn't have to run that low of a offset ??
Reply 0
Jun 27, 2010 | 09:30 AM
  #928
Quote: ok then what would be a mild stretch so i wouldn't have to run that low of a offset ??
A mild stretch would be a 235/245 or 225/235 setup. You should be low with the tire at the fender (or tucking a bit of tire is even better). Offsets (assuming no fender pull and you are cool with running some negative camber) would be anywhere from +15 to +5 in the front and +20 to +15 in the rear.
Reply 0
Jun 27, 2010 | 02:35 PM
  #929
go lower! get_some35 hahaha. front needs alot more low rear just alittle bit more
Reply 0
Jun 27, 2010 | 05:34 PM
  #930
Quote: go lower! get_some35 hahaha. front needs alot more low rear just alittle bit more
yeahh... but i cant choose uas or phantom cup kit? im leaning towards phantom cup kit.. driving at parked height and just going up when i need clearance
Reply 0
