The "Look what I made/installed/modified today" thread.
Old Nov 1, 2012 | 12:25 PM
  #2266
CandlestickPark's Avatar
ill Sedan
How did you get the color to match?
Old Nov 1, 2012 | 01:42 PM
  #2267
Shanes_G's Avatar
Fred paints cars professionally
Old Nov 1, 2012 | 02:07 PM
  #2268
MPG35fiend's Avatar
Originally Posted by G35Papa
So many new mods Fred Love it Good work. Do you do body work/paint professionally?
Thanks Chris! And yea i do paint work professionally.. Hahaha info all my own work to save $$$! That explains all the new mods
Old Nov 1, 2012 | 02:12 PM
  #2269
MPG35fiend's Avatar
I bought my paint from shermin willams. Paint never ever mathes perfectly so I had to tone it to match 100%. Always best when car is present to match it with. Honestly I got lucky to get it that good.. I paint all the g's around my area.
Old Nov 1, 2012 | 02:14 PM
  #2270
MPG35fiend's Avatar
Thanks! You know I take care of you!
Old Nov 4, 2012 | 11:43 AM
  #2271
G35Papa's Avatar
Very cool. A skill I wish I had!
Old Nov 28, 2012 | 09:06 AM
  #2272
NjMatteSedan's Avatar
Old Nov 30, 2012 | 04:56 PM
  #2273
Adro's Avatar
Originally Posted by BlkSedan4me
sweet!
Old Dec 2, 2012 | 11:16 AM
  #2274
3pedalsdn's Avatar
color matched my moldings and side view mirror bases... it was a pain in the *** taking those trim pieces off..SMH it was well worth doing it though..... i learned a lot doing it. doing door handles after Hurricane Sandy passes through. then installing jdm window visors.
how exactly do u remove the window trim without bending/breaking it? I've been debating painting or wrapping mine...
Old Dec 8, 2012 | 01:43 PM
  #2275
naughty240's Avatar
^ its a bitch. You have to pull all the rubbers off first along with the screws. To pull it out you gotta start at one end it kind of peel from the door to the roof gently. Once you get it to separate a little it comes off as you go. Think mirror may have to come off too.
The rears are the hard ones. I dropped the glass and removed the little window along with the post to get access. I believe there is a little two way tape on the curve part so that requires a lot of finesse. The straight part comes off just like the front. I had a DIY I made for this but I dont know where it is.
I would not attempt this project unless you are prepared to buy new ones. They are delicate and bed easy. I bent one of mine and it took me forever to hammer and dolly it back to new.
Old Dec 8, 2012 | 01:57 PM
  #2276
3truman's Avatar
I agree with naughty, its easier to paint them while on the car. It takes less time to mask off than to remove and reinstall, and you dont have to worry about bending or breaking any of the pieces. I pulled mine off the first time and when i repainted them this year i did it with them on the car. It came out better and it took less time to do. The mirrors do have to come off. Its not hard but why go through all the trouble?
Old Dec 8, 2012 | 02:02 PM
  #2277
naughty240's Avatar
Only problem with leaving them on is you may not be able to get the self etching primer on the edges like you need to. They will probably peel a lot faster.
Old Dec 9, 2012 | 08:28 PM
  #2278
JaE35's Avatar
Moderator
G35 Sedan
New front, and yes my inspection is out lol
Old Dec 9, 2012 | 09:21 PM
  #2279
MPG35fiend's Avatar
sorry for the late response.... havent been as active on here as i use to...
it was a pain in the ****... had to remove all the interior door panels. i followed a DIY on here which helped a whole lot, but the rest was common sense. just be very careful on the lower door trim bc its a bit tricky to take out and the very rear trim on the rear doors are double sided taped on and will be the hardest part to take off with out damaging it.. this mod is very time consuming to do but worth doing IMO as long as it flows with your theme. i dont regret doing mine at all... good luck!!
Old Dec 9, 2012 | 09:22 PM
  #2280
MPG35fiend's Avatar
NAZTY!!!!!!!
would look good with gloss black grille too...
