The "Look what I made/installed/modified today" thread.
Old Mar 5, 2011 | 07:12 PM
  #451
kennymo's Avatar
zero sand paper has been used. do i need to sand it? i thought since it was smooth i didnt have to, ive just been rubbing polish on and then wiping it off with a clean rag
Old Mar 5, 2011 | 07:17 PM
  #452
DrewLe's Avatar
Gotcha. Well mines a little dirty so I use really fine sandpaper to get the surface gunk off, then the compound as well.
I'm still learning the best method to do everything so don't take me word for word.
  #453
kennymo's Avatar
oh ok. maybe i will try the sandpaper method tomorrow when i do some more. and see how that goes. what grit should i use? like 2000?
Old Mar 5, 2011 | 07:31 PM
  #454
DrewLe's Avatar
Well considering I get slight streaks from the coarseness of 120 grit after the compound, something like that would prob be best.
Old Mar 5, 2011 | 07:33 PM
  #455
CandlestickPark's Avatar
ill Sedan
Kenny definitely try the sand paper method, I think you'll see even better results. Nice work so far.
Old Mar 5, 2011 | 07:34 PM
  #456
kennymo's Avatar
so i sand. then polish? does it need to be wetsand or can i dry sand or does it not matter?
Old Mar 5, 2011 | 07:35 PM
  #457
SN00P's Avatar
CLUB MODERATOR
i started doing mine a few months ago and gave up using polish. i also didnt use sandpaper but i rather just buy a polished timing cover lol
Old Mar 5, 2011 | 07:39 PM
  #458
DrewLe's Avatar
Sand then polish. No point in sanding something you've spent hours on to polish lol.
Old Mar 5, 2011 | 07:41 PM
  #459
kennymo's Avatar
haha ok.
Old Mar 6, 2011 | 12:20 AM
  #460
Epidel's Avatar
This is defiantly a project i want to attempt. What if you could get a buffer in there, i am sure that would speed things up.
Old Mar 6, 2011 | 12:39 AM
  #461
G35Papa's Avatar
^polishing bit on a dremel would fit in there
Originally Posted by iiiiiekoiiiii
enjoy the paddle shifters man,
Drove the car with those shifters so many times, Loved it each time.
I was very closed to taking them but took his Brembo bbk instead =X lol
Ah, so you were the one that Anar was waiting on to decide if you wanted them or not....thanks for not buying them I haven't been able to use them yet....waiting to get an intake back in my car.
Originally Posted by GGG-G35
Chris, paddle shifters FTW man....Dope..
Thanks Chris
Sand, sand, sand, then polish. I haven't started mine yet but it's like polishing stainless bolts. I typically run through 3 grades of sandpaper before polishing. 400, 800 then 1500. You will never get it to really shine unless you use sandpaper first. bigc did his by hand and it looks amazing
Old Mar 6, 2011 | 12:45 AM
  #462
Epidel's Avatar
ok so 400 800 and 1500 got it!
Old Mar 6, 2011 | 12:50 AM
  #463
G35Papa's Avatar
That's for stainless bolts....lol...the cover will take more than that
Old Mar 6, 2011 | 01:41 AM
  #464
kennymo's Avatar
even a polishing bit on a drimel would be hard to get in some areas. just because of the angles that you would have to put it at. but by hand is THAT hard. its just very time consuming
Old Mar 6, 2011 | 04:14 PM
  #465
Epidel's Avatar
so im going to need stronger paper then
