3 inch Mandrel Bent Exhaust // HKS LEGAMAX (3 inch)
Old 02-11-2011 | 07:12 PM
Eric@TCGMiami's Avatar
Ok, I finally got around to buy the bends and pipes needed to make the full 3 inch Stainless Steel exhaust.
My previous setup went as follows:
DC Sports Headers, Crawford Z High Flow Cats, Top Speed Pro-1 Y-Pipe, 2.5 Inch Custom MagnaFlow Mid-Pipe, HKS LegaMax Dual Tipped Muffler.
Sizes:
2.25 > 2.25 > 2.5 dual to 3 inch flange, 2.5 Flange to 2.5(HKS)
The car had some rasp. Made good torque but lost the top end power. Overall I was happy with the setup but did not like the rasp.
So here is the new setup:
DC Sports Headers(2.25), Crawford Z HFC's(2.25), Top Speed Pro-1 Y-pipe(2.5dual to 3inch flange), 3inch Flange to 3 inch extreme Racing Technologies full race (Square Oval 3inch in 3 inch out), removed the 2.5 pipe that comes from the HKS Legamax and welded a true full 3 inch 304 stainless steel section onto the HKS muffler.
Extreme Technologies Racing Muffler:
http://www.extrememufflers.com/index...2046151a6c5542
HKS Legamax Sedan Muffler:
32008-BN001
KS Sport Exhaust System (Stainless Steel Rear Muffler Only/Dual Tip) 83 dia tip dual / 65mm pipe for Infiniti G35 03-UP (Sedan Only)
65mm = 2.559inches
83mm = 3.267inches
The internals of the Muffler made me change the pipe collecting the gases.
The Dual tips are isolated, spectacular interior and exterior construction.
each isolated area is 1.524 inches in diameter. So going full 3 inch did not hurt the muffler one bit.
Additionally, the HKS Legamax Muffler has one flaw from factory. there is a slanted plate bracket which is designed to act as a relief for weight/vibration/tension so that the pipe does not crack at the point where it meets with the canister. It is welded on from the bottom ... (fail). I cut it off, and welded the bracket on the topside.
Here are some pics:
Here are the videos:
(Apple Quick Time)
(Flash Player)
Definitely opened the engine to more power past 5k RPM... before the engine would choke.
Welds were made thick intentionally. I hate it when pipes crack because of thin welds, usually I've found that Stainless steel (thin walled) cracks easily when the welds are thin mostly due to the fact that you are slightly distorting the metal in such a thin area. By making it thick it'll hold around the flanges a lot better. (It's tried and tested by me at the least).
Old 02-11-2011 | 07:30 PM
kennymo's Avatar
you have the pipe that you removed still? if its what i think it is i might be interested in buying it
Old 02-11-2011 | 07:33 PM
Yes, I have it.
all 304Stainless Steel. 2.5 with the Magnaflow Attached.
Old 02-11-2011 | 07:37 PM
kennymo's Avatar
can you pm me a picture and price please
Old 02-11-2011 | 07:45 PM
This is my previous setup before the 2.5 mandrel.
Http://www.tcgmiami.com/g35/g35drive...om Exhaust.mp4
Top Speed Pro 1 headers Stock Cats Y-Pipe Custom 3 inch mid pipe with Extreme Muffler in sub section HKS Legamax Muffler.
Here is the 2.5 Mandrel which I removed:
Old 02-11-2011 | 07:46 PM
kennymo's Avatar
how much do you want for that whole peice?
Old 02-11-2011 | 07:47 PM
Are you local?
I honestly didn't plan on selling it as I have other project cars but It's really a cut and weld for the G sedans. I'm willing to help you out.
PM ME an offer (remember plus shipping if you are not local).
Old 02-11-2011 | 07:49 PM
thescreensavers's Avatar
Mr.202?
Lol cant see any of the videos or links for that much in Ubuntu, can you put them on youtube?
Old 02-11-2011 | 07:52 PM
Sure..
how have you been!!!!!! ???
Old 02-11-2011 | 07:57 PM
Old 02-12-2011 | 05:13 AM
Old 02-12-2011 | 05:14 AM
Old 02-12-2011 | 06:35 AM
chink-ah-saur's Avatar
Nice..182k dammmmm
Old 02-12-2011 | 08:07 AM
lol....
Yeah, she's got some wrinkles on her sleeves. But she still can pull a train on many rides.
Old 02-12-2011 | 01:07 PM
Equipped4dr's Avatar
Whoa, i thought it said 102k fuuk
Quick Reply: 3 inch Mandrel Bent Exhaust // HKS LEGAMAX (3 inch)
