custom exhaust build
Old Mar 4, 2011 | 12:30 AM
  #106
kennymo's Avatar
Originally Posted by Andrei
You're the kind of guy I could have a beer with. A real DIYselfer. An entrepreneur. A go getter. You could of done what everyone else is doing and spent over $1000 with Stillen. Because the Stillen one has pixie dust on it.
come to the bay area. we will drink while im building it haha
Old Mar 4, 2011 | 12:46 AM
  #107
Eric@TCGMiami's Avatar
Originally Posted by forweareLegion
Why do people have to sh|t in other peoples build threads.
I built my own exhaust last spring. I went 2.5" pipe from the cats to a dual 2.5 in, 3" out magnaflow 'y' muffler. There's one short resonator before the rear subframe, plus the dual 3" blast pipes and that's it. It's all pie cut, so the fit it as good as it can get, but it's certainly not for anyone without saint like patience.
The short of it is I copied a proven setup (pie cuts aside) and it worked out. If you copy the stillens for example to the best of your abilities it should work out fine. And it'll be noisy haha.
This thread lacked knowledge, we provided great arguements which will serve to someones future.
OP, you ask what is a mid-pipe. Take note at his setup. He has a small resonator in the centerof the car before the rear axle muffler.
Old Mar 4, 2011 | 01:03 AM
  #108
kennymo's Avatar
ok so should i add a resonator on each one of my pipes ?
Old Mar 4, 2011 | 01:08 AM
  #109
chink-ah-saur's Avatar
yes
Old Mar 4, 2011 | 01:09 AM
  #110
kennymo's Avatar
other than make it quiter is there a purpose to it?
Old Mar 4, 2011 | 01:11 AM
  #111
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by 3truman
If stillen has pixie dust on it what does my full motordyne have on it??????? Lol
A mixture of Unicorn blood, platinum dust, and Unobtainium.
  #112
After much trial and error on my part. I would consider to do so unless you want nasty rasp and drone in the car.
Old Mar 4, 2011 | 01:13 AM
  #113
kennymo's Avatar
ok thanks for the heads up. i think for right now i am just going to build it and get it setup and then once its done and on i will find 2 resonators and figure out where i can fit them and then weld those in
Old Mar 4, 2011 | 01:26 AM
  #114
Honestly i'd consider getting a canister 2 in 2 out vs the twin resonators... had that and wasn't pleased. It substantially brought the noise down but was where near the canister. Just finding a straight through twin in/out is hard to find at a reasonable cost.
Old Mar 4, 2011 | 01:30 AM
  #115
NFSP G35's Avatar
? = 2B || !2B
I don't understand "but was where near the canister."
Old Mar 4, 2011 | 01:41 AM
  #116
kennymo's Avatar
so you are basically saying that i should try and find a dual in/out gutted muffler style resonator?
Old Mar 4, 2011 | 02:15 AM
  #117
Sorry was typing from the phone and talking to some chick at the same time... fkn fail.
And yes to op
Old Mar 4, 2011 | 09:51 AM
  #118
forweareLegion's Avatar
Magnaflow makes a really nice one;
http://www.magnaflow.com/02product/s...e=main&id=9256
It's got a perforated x pipe inside it. If you search a bit I know there's cutout pictures of them. Having used many magnaflow products over the last few years and never having issue I have to recommend them. If you add one to your system it will considerably lower rasp and will deepen the tone a little.
Old Mar 4, 2011 | 02:02 PM
  #119
26th street's Avatar
Good **** can't wait to see the finished product..
Old Aug 14, 2011 | 08:18 PM
  #120
Max626's Avatar
what ever happened with this build?
