My bixenon projector retrofit
Old Mar 16, 2011 | 10:42 PM
r1forever80's Avatar
I used d2s bulbs. I dont use the adapters. I make mounting brackets for all locations. Ive put fx35, tsx and s2k projectors up top with no problems. The fun task of putting a tl bixenon down low was fun cuz the solenoid was huge on that thing. When i put the morimoto mini up top there was plenty of room. The mini is a good projector but no way compares to the s2k or tsx. Deffinately a good bang for the buck though
Old Mar 16, 2011 | 10:53 PM
acr's Avatar
acr
I'd like to try an FX-R retrofit at some point. Why use a TL vs an FX-R though? I read they're very comparable.
The S2k and TSX are both low beam only so they weren't really an option for me. Their cutoffs look really nice though.
Old Mar 17, 2011 | 01:33 AM
b-dRizZy's Avatar
Originally Posted by GGG-G35
very nice man....you guys are making "Retrofit" look easy...I might have to tackle this myself.
Doooo itttttt !!! Bro will go perfectly with your nismo <JdM> look
Old Mar 17, 2011 | 02:53 AM
JDM_Cain's Avatar
^RIGHT!! Its on the to-do list...but got priorities..
Old Mar 17, 2011 | 09:22 PM
NFSP G35's Avatar
? = 2B || !2B
My cousin showed me those kits on the retrofit source. Very nice
I know what you mean, the projectors I used have huge solenoids on the side It was a huge pain and I finally had to end up fabricating brackets.
Old Mar 18, 2011 | 01:31 PM
acr's Avatar
acr
do you have any pics of your retrofit? i'm curious to see the routes others have taken with their retrofit.
Old Mar 18, 2011 | 01:52 PM
NFSP G35's Avatar
? = 2B || !2B
^Quite a few, but I'm waiting until I get everything finished to post pics.
Old Apr 11, 2011 | 07:29 PM
acr's Avatar
acr
any updates on yo retrofit?
Old Apr 17, 2011 | 04:40 PM
acr's Avatar
acr
A member asked me a question about how I wired the projectors, and I thought I'd post the answer on here in case it helps anybody else.
My car has the premium package w/ automatic headlights.
I set up the projectors as follows:
I mounted the projectors in the fog/high reflector bowl simply because it is larger, requiring less shroud/bezel trimming. Plus, the Morimoto projectors can be mounted in the existing H4 bulb mount. You have to modify the projector body to get the cutoffs straight with the H4 adapters, but it was still easier than fabricating mounting plates. I ordered D2S projectors rather than H1 projectors because our cars come with D2R bulbs from the factory. D2S/D2R bulbs are identical except D2R bulbs have sort of a sticker on the bulb that creates a cutoff, necessary in reflector lights.
I simply hooked up the factory ballast/ignitor to the projector. The ignitor is plenty long enough to reach the projector mounted in the fog/high location. I then tapped into the H4 bulb socket wiring to ground the ignitor. This arrangement means that when I turn on the low beams via the stalk, the projectors fire up.
To power the high/low solenoid, I simply tapped into the now unused H4 bulb socket that's in the headlight. I spliced the solenoid leads so that when I toggle the high beams on from the stalk, the bixenon solenoid is activated by the H4 socket and thus I get my high beams.
The headlights function normally except there are no fog lights. The stock foglights are useless anyways. The factory low beam is also not hooked up, but there is a bulb in there just so it looks normal.
If you wanted to, you could install some LEDs or halos in the lights and use the fog switch on the stalk to toggle those on/off.
Old Apr 17, 2011 | 04:47 PM
NFSP G35's Avatar
? = 2B || !2B
^Or adjust your factory low down a bit, replace it with a 3000k bulb, add another HID ballast, and wire it to the fog
Old Apr 17, 2011 | 04:51 PM
acr's Avatar
acr
I did consider doing that. Unfortunately the way the Morimoto projectors mounted up I had to adjust the headlights waaaaay up to get a normal cutoff height. So if the factory lows were powered, they would be pointing to the sky.
But yeah, if you aimed the factory low down so that it could function as a fog before making/aiming the projector mounting plates, it would look pretty cool.
EDIT: forgot to mention that the highs/lows are aimed together. It sucks they can't be adjusted individually. Not to mention the 05-06 lights don't have lateral adjustment built in, unlike the 03-04 lights...
Old Apr 17, 2011 | 04:57 PM
NFSP G35's Avatar
? = 2B || !2B
^LOL. Then you could spot incoming air-raids!
I get what you're saying.
I did that with mine, but I fabricated mounting plates and sliced the reflector in half.
I don't use my old low/fog at the moment, because they're pointed at the trees too. I just have to wedge something under them to adjust them down.
Old Apr 17, 2011 | 05:00 PM
acr's Avatar
acr
I'll be blinding pilots left and right. Do you have any pics of your headlights?
Old Apr 17, 2011 | 05:06 PM
NFSP G35's Avatar
? = 2B || !2B
^Yep.
Here: http://www.nfspmotorsports.com/forum...;sa=album;id=5
and here: http://www.nfspmotorsports.com/forum...sa=album;id=14
Old Apr 17, 2011 | 05:10 PM
  #30
acr's Avatar
acr
Very nice. Projectors really set off G35 sedans.
I also like the turn signal lens. I'm going to do that mod this summer, along with painted bezels and reaiming the projectors.
