My bixenon projector retrofit
Old Apr 17, 2011 | 05:11 PM
  #31
NFSP G35's Avatar
? = 2B || !2B
^Thanks. Yeah, they were a pain
Old May 7, 2011 | 11:28 PM
  #32
RodzMax2002's Avatar
Very nice man..I wouldn't even have the guts to even attempt this on my headlights,I would rather buy another set,that way If I mess something up im good..lol Nice work man..
Old Mar 13, 2012 | 04:08 PM
  #33
socialconflicts's Avatar
sorry to awaken a thread from the dead, just had a question. how would i go about making my lower bixenon work like oem (fog/hi beam) without having a switch to turn on the bixenon..
Old Mar 13, 2012 | 04:11 PM
  #34
r1forever80's Avatar
You can't unless you somehow bypass the bcm
Old Mar 13, 2012 | 04:18 PM
  #35
so for the jlc quads i had they bypassed the bcm? so the only other option is to run a seperate switch?
Old Mar 13, 2012 | 04:25 PM
  #36
Depends on how they had them configured. I have not found a way to bypass the bcm using the oem wiring and oem switches because when you turn on the hi the fog turns off. So if your using the fog as the low beam on the bixenon and turn the hi the solenoid will move but the light will shut off. I doubt they had them set up that way but could be wrong
Old Mar 13, 2012 | 04:27 PM
  #37
If you had quads they probly had the hi/lo up top and used the lower projector for fog is my guess
Old Mar 13, 2012 | 05:03 PM
  #38
The way they had it setup was oem style. But now that i think of it i think ur right. I remember my fogs were turning off when i thrned my hi beams on. And the top would stay on. So how would that be any different? Sucks now that thats the case. Cuz the bixenon in trying to set up now is on the bottom.
Old Mar 13, 2012 | 05:09 PM
  #39
They didn't have the fog on the same projector as hi before. Now your trying to but it won't work. If your just trying for the single projector down low you will have to move the low to the bottom and have to lows and no fog or put the low/hi down low and make the top reflector the fog or run a seperate switch
Old Mar 13, 2012 | 05:24 PM
  #40
So if i move the bixenon in the bottom to the top would i need to do anything to have the top work at my low and high beam?
Essentially what i want is my my lower just working as fogs and tops as lo and hi beams
What would i need to make it work like that?
Old Mar 13, 2012 | 05:29 PM
  #41
From what I understand your running a single bixenon projector. That's really simple. Move the projector to the top. Make sure you get a d2s or dr2 projector is your using oem hid lights. The low beam will be as usual. On the bottom plug that goes on bulb you will cut the hi power and run it to the solenoid up top in the projector.
Old Mar 14, 2012 | 03:26 AM
  #42
would this work?
http://www.hidplanet.com/forums/show...ogen-high-beam
Old Jul 16, 2013 | 01:43 PM
  #43
acr's Avatar
acr
My lights are now for sale if anybody's interested!
Old Jul 16, 2013 | 10:36 PM
  #44
FlyingLumpia's Avatar
Dang you had to be 05-06
Old Nov 14, 2013 | 04:53 PM
  #45
Fire0nic3's Avatar
Bro please help
I did exactly what you did put when I try to aim the projectors to go up they wont. It seems like the pojector hits the bezel inside?? I mounted in the hi/fog location just like you.
Why did you trim the bezel though in your first picture?
