need pics 19x10.5 with +12 offset on 03-06 sedans
sorry, but that wheel lip looks like it will hit the fender, not sure that it does fit. Have you removed the rear spring and checked full motion of the wheel? You don't want to hit a big bump and **** up your fenders
when i had it lower than this it was hitting the lip. but im driving it as is for a week now and no rubbing or fender issue . and yes i am on coils but danpening is right in the middle
how would 19x9.5 +12 look in the rear? (already know how it looks in the front, saw a pic on the first page.) thinking about doing 19x9.5 +12 all around
Can you adjust camber up front without aftermarket camber kit? I was going to order just the rear camber kit and adjust to negative camber so I can get the wheel to sit flush, but wasn't sure if I needed the front as well. But I don't want the fronts to be sticking out while the rears are sitting inward. A board member told me that I wouldn't need it however. Any input?
bu villain
19 Inch
Nov 15, 2015 09:23 PM
yoyoyo8
Aug 12, 2015 03:04 AM
