2013 370z Sport Rays on my G35S
Old Feb 4, 2014 | 04:35 PM
G35DriverNC's Avatar
Looks good!! Do you have side view pic of the rear tire poking out? Just curious....
Having the better grip during hard acceleration will definitely improve the driving experience. I hate when the traction control turns on and slows me in my tracks when I need to GO!
Don't worry about the little extra weight (mass) it is so miniscule that it will never be noticed.
Old Feb 4, 2014 | 04:37 PM
WhosUrBuddiee's Avatar
I will add, that if the Rep was referring to wider tires by saying larger, then No it does not affect gearing, RPM, or speedometer. Only way wider tires could effect your car is if it was AWD.
Old Feb 4, 2014 | 04:57 PM
E-Ticket Ride's Avatar
Originally Posted by WhosUrBuddiee
370Z sport wheels
19x9 Front: Rim 23.2lbs With tire/stock 52.2lbs
19x10 Rear: Rim 23.9lbs with tire/stock 56.8lbs
G35 sedan
18x8 square: Rim 18.3lbs With tire/stock 49lbs
I believe that wheel weight is wrong, as the OEM 18" sport rim is cast (not forged) and IIRC isn't 18.3 lbs.
Here's another weight thread I found:
https://g35driver.com/forums/g35-sed...ms-weight.html
To the OP, setup looks sick!
Old Feb 4, 2014 | 05:00 PM
^^^ Forgot OP has a 2nd Gen. I put spects for 1st gen with 18x8 square set up.
Old Feb 4, 2014 | 06:27 PM
Sport35Driver's Avatar
Forgot? I posted a picture of my 2nd gen in a thread you're responding in...
Old Feb 4, 2014 | 06:29 PM
here's a front shot
Rear shot
Old Feb 4, 2014 | 09:39 PM
vqsmile's Avatar
To the OP: my apologies for this distraction.
Common sense would dictate that when someone says larger, they again are talking about OD. When someone is talking about width, they say wider.
Yes kid, larger tires do in fact lower your RPM for a set speed and cause an error in your speedometer, this is common knowledge (for most). You speedometer is calibrated so that for each rotation, you car is assumed to have traveled a specific distance (the outer circumference of your tire). So if you install a larger tire, your OD increases and the distace your car travels per rotation increases, lowering your RPM for a set speed. Please stop giving adivce on simple subjects where you obviously lack the necessary knowlege. While a larger tire doesnt physically change your gearing, it does effectively change your gearing.
(New Tire Diameter/Old Tire Diameter) x Old Gear Ratio = New Gear Ratio
So again, if the Sears Rep was talking about larger tires changing his gearing, he was technically correct.
Other than using and interpreting vague and subjective adjectives to support your own (again) subjective interpretation, you have added nothing here other than a childish display for all to see.
I can infer from your response here that you apparently weren't even talking about the added mass before as I initially suspected (I guess that was giving you the benefit of the doubt). Nope, you were just plain old ASSuming what was meant by the rep (hack) at Sears to contradict me, even though all the while, you have basically agreed with exactly what I initially stated ... AND which you inexplicably told the OP to ignore:
Originally Posted by vqsmile
Tread width has N O T H I N G to do with effective gearing, it's all about overall diameter.
It makes me wonder if you even read my posts at all or just decided to rag on them because you're apparently the self appointed "enforcer of common sense". (pfff give me a break)
Try practicing your reading comprehension and learn to communicate clearly before you demand that you're correct and make personal swipes at people. (Hint: presumption and sanctimony are not flattering.)
Words like "bigger", "larger", "size" are poor choices if you really mean taller, wider, overall diameter, etc.. Further, I do not believe for a second that when the average person mentions getting "bigger" or "larger" tires on their car that they are referring to the height or overall diameter. Instead, they are just using the terms loosely to refer to a wider tire choice (aka. 'meats' and so forth), so your assertion (ASSumption) that common sense dictates "larger = OD" is absurd. (Seriously, who makes a deliberate choice to put taller tires on their car anyway??).
In conclusion, I stand by everything I said. Any statement I made was supported with specific language to clarify any ambiguities. In contrast, your statements, were essentially only reiterating exactly what I had already stated, yet were adding further ambiguity until just there, in your very last sentence, that you offered an "if" clause alluding to the context of your remarks. Although I don't know why you said "again", because it was the first time you mentioned it. (Was the other time just in your head perhaps?)
If you choose to respond to this post, please leave off any further personal attacks and just cite specifically where I posted anything that was incorrect.
Btw, being well over half a century old, the "common sense" I've picked up over my years tells me to just thank you for your nice compliment about my age.
Old Feb 4, 2014 | 10:49 PM
Originally Posted by Sport35Driver
here's a front shot
Rear shot
I really like the look from the side view but a sticking out quite a bit in the rears. There is no way you can lower that car without major damage to the quarter panel.
I have seen some use front Z wheels in the rear for a perfect fit but not staggered of course. Good for rotating and tire wear but you have to buy them individually (extra fronts) or have two sets with four rears left over!
I so wanted to go with the Z wheels but didn't due to this issue. I went with the M 19's instead.
Old Feb 4, 2014 | 11:29 PM
The stock 275s will fit when it's lowered without modification. If you wanted to be really safe a 265 width tire would be fine. It's all about how aggressive you want to be with your rims and tires. For me I hate the stance look. I really would much rather stretch the fenders and stuff some meat in there!
Old Feb 5, 2014 | 09:15 AM
joedaddy1's Avatar
looks like you need to switch left/right.. the rims look like they turn the "wrong" way now..
it just looks better.. right now it looks like the spokes are "turning" the wrong way.
Old Feb 5, 2014 | 01:14 PM
No, they're facing the correct way.
Old Apr 1, 2014 | 02:14 PM
samuel1021's Avatar
Moar low.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
