Help with Vdc/slip light
Old Oct 9, 2014 | 07:31 PM
Hratch818's Avatar
my vdc and slip lights dont turn off. but also dont turn on till i turn the wheel even slighty. just wanna find out if we can fix this. cause we all know how fun it is without traction
Old Oct 9, 2014 | 11:30 PM
Urbanengineer's Avatar
Look at the cam sensor replacement guide. I think that is your issue.
Old Oct 10, 2014 | 02:05 AM
westsideblu's Avatar
It could be the abs sensors up front maybe the plugs are loose if its just the slip and vdc lights thats probably the problem. The abs is tied in to the traction control and vdc which is why you cant line lock with these cars (without solenoids) lol
Old Oct 11, 2014 | 03:31 PM
Hratch818's Avatar
where can I find the plugs? Can I do it myself
Old Oct 12, 2014 | 01:54 PM
Cingular's Avatar
Are the lights the problem and or is the VDC button not working?
Old Oct 13, 2014 | 02:12 AM
Hratch818's Avatar
the button works if I just turn my car on and don't turn the wheel once it moves slighty left it turns on. If I turn the wheel right it's fine
Old Oct 13, 2014 | 08:04 AM
Maybe you have a bad clock spring... Just saying.
Old Oct 13, 2014 | 12:21 PM
https://g35driver.com/forums/attachments/brakes-suspension/161237d1378476590-abs-sensor-wheel-bearing-hub-dsc03733.jpg
this is the front wheel speed sensor for the abs system theres this sensor and it goes to a connector on the frame. Does your car have cruise control? Steering wheel audio controls? You could do a quick check for a bad clock spring by checking if all the steering wheel functions work (cruise control, audio, horn). But if you take it to a shop if its the abs sensors itll pull a code if I remember correctly and most shops its free to scan your car.
Old Oct 13, 2014 | 01:28 PM
Hratch818's Avatar
Thanks man, everything on my steering wheel works perfectly fine
Old Oct 14, 2014 | 12:58 AM
I also found out today that if the maf plug isnt plugged in itll cause the slip, vdc light will come on along with the ses light though lol
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Jnm07
Sep 5, 2015 01:16 AM
