check engine light VDC and Slip light
Old Oct 27, 2018 | 01:33 PM
snunez's Avatar
g35 coupe base
2004 infiniti g35 coupe base 136k miles
Going to try and make this short. After getting the check engine light for both cam position sensors each about two year apart replaced them and car drove fine my latest one i replaced was passenger side got the check engine light replaced it car ran good for about two weeks. got the light again so i took the sensor back thinking it was bad, they gave me a new one replaced it still having issues. replaced the crank shaft sensor still having issues.
common symptoms
1. occasionally difficult to start
2. will die at a stop sign
3. will stall/jerk going down the freeway but doesn't die, corrects its self after vdc light slip light comes on
4. radio will occasionally cut out after starting car for about a second or two
Please help if you can
Old Oct 27, 2018 | 03:29 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like you're not using the OEM Nissan or Hitachi sensors. This is a common problem with aftermarket sensors.
The radio problem however sounds like a failed head unit but I would troubleshoot the power circuit to rule out an electrical problem.
Your VDC light coming on is probably unrelated to the engine controls system, scan your vehicle to find out what's triggering the VDC system to go crazy.
You probably have 3 unrelated problems with your vehicle however since they all share one commonality, THE BATTERY, I would check the connections on it, both cables, both ends of each cable.
Mark7
Dec 21, 2019 06:22 PM
bendigi
Mar 20, 2015 12:44 AM
RoDzG35
Apr 27, 2010 03:01 AM
netcbc
Canada
19
Dec 3, 2007 06:10 PM
