P0300 Code Help please
Old Mar 25, 2020 | 03:50 PM
ShoTheG35xOwner's Avatar
G35x
Cool P0300 Code Help please
So, I have a 05 G35x & Car smells gassy, Idling high & Shaking not sure what the problem is, I’ve checked the coils already someone said it can be a vacuum leaks but don’t think it is
Old Mar 25, 2020 | 05:45 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Pull and inspect/replace your spark plugs is usually the first culprit.
Old Mar 26, 2020 | 10:43 AM
Chrisv673's Avatar
Infiniti g35 sedan journey
Had the same issues. Ended up replacing coil packs , ordered 6 NGK coils from CARID.com $267 for all (6). Went to nearest auto parts and purchased new ngk spark plugs, pcv valve and cleaned out throttle bodies and cleaned the mass air flow sensors, also had an emissions code for the purge canister solenoid i ordered from Amazon $30. Got it up and running like new!
Old Mar 28, 2020 | 10:43 AM
tiguy99's Avatar
How difficult is it to access the coil packs on this motor?
Recently had the same stuff done on my wife's RX300 but had a shop do it after hearing how involved the process was for that car.
Old Mar 28, 2020 | 01:14 PM
cleric670's Avatar
BANNED!!!
Super simple, they're on the top of the valve covers. Right side is 100% accessible without removing any other components, left side you need to remove the intake pipe.
Be sure to label the harness wires so you don't get them mixed up, torque is 62 INCH lbs.
I'm sure there are plenty of youtube video's to watch as well.
Old Mar 28, 2020 | 11:47 PM
Chrisv673's Avatar
Very simple to do. Remove both air intakes. Remove the 4 screws for the throttle bodies but do not disconnect them, just remove the screws And move it out of the way to access the coil pack #5 and #6. Standing in front of the car the sequence is as follow left side 1,3,5 right side 2,4,6....
Old Mar 29, 2020 | 12:09 AM
cleric670's Avatar
BANNED!!!
The OP doesn't have that engine, he has a V35 platform, no need to remove throttle bodies.
Biguuey
Feb 12, 2020 04:37 PM
