New member needs help
Old May 1, 2020 | 08:55 PM
Jhordano's Avatar
G35x 2005 162xxx miles
Hey I have a G 35X 2005
I need new seats also and middle trims
Side lights
my catholic converter is clogged it smells like gas all four windows don’t come down it has about 160,000 miles my lighter fuse keeps burning
Old May 1, 2020 | 10:33 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Remove the cats and look for melted spots, ring out the lighter circuit and find out where it's shorted out.
Cats usually smell like rotten eggs when they finally cook off, if it smells like gas they haven't totally cooked yet but might be damaged so you should do a visual inspect.
Also pull your plugs and see what's going on in the combustion chamber, the condition of the plugs will tell you almost everything you need to know.
That "catholic converter" though... lol.
Old May 1, 2020 | 11:45 PM
Jhordano's Avatar
thanks anything on the windows ? All four of them don’t do anything the lock button also don’t do anything
Old May 2, 2020 | 12:56 AM
cleric670's Avatar
BANNED!!!
Put the key in the door lock and hold to the unlocked position, should roll all 4 windows down (locked position will roll them back up). If it DOES then the problem is likely just the driver window switch which is the master switch that they all come back to.
If not then you're going to have to start ringing out wires back to the BCM to see if there's any broken wires in the door harness, sometimes they break at the flexible section where the door hinges. Ring out the functions of the button assembly to make sure circuits can complete. Also check for blown fuses in the cabin fuse box.
FSM sections BL - Body / Locks, section GW - Glass / Windows
https://www.nicoclub.com/infiniti-service-manuals
Lingcod
May 4, 2020 11:29 AM
Christian Perez
Apr 20, 2020 09:24 PM
KDomfeh23
Mar 7, 2020 09:12 PM
bubbapark
Sep 1, 2019 05:00 AM
