My 2003 g35 sedan won’t start. Please help!
Old Jul 23, 2021 | 06:53 PM
pink carbon g35's Avatar
pink metal flake black carbon fast neck breaker
I put a new battery. I put new coil packs in it. I put new spark plugs in it. I put a new after market intake in it. I replaced hoses. I put new battery cables and connectors. I did do the muffler and resignator delete. I put aftermarket steering wheel. I did get a code on the obd2 saying the acds switch needs to be replaced but once I removed the plug and wire from putting new steering wheel in it went away. Light come on it powers up but when I turn the key over all I hear is a click click clicking noise. I also tried to jump start with another car and still nothing. What do I do now? Please help! Thank you
Old Jul 23, 2021 | 07:58 PM
telcoman's Avatar
Veteran: Army
Have you read the troubleshooting steps in the FSM?
https://www.nicoclub.com/service-man...F2003%2Fsc.pdf
See page SC-9
Remove and bench test your starter
If it turns out that is your problem, have it rebuilt rather than replacing it.
Good luck
Old Jul 23, 2021 | 09:38 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That clicking sound is the starter solenoid chattering because there isn't enough cranking amps supplied by the battery. Jump starting only works if you let the other vehicle charge the battery of the one trying to start.
Put a charger on the battery and GET THE THING FULL then your starter will work. If it still won't work and chatters after you FULLY CHARGE then the battery won't hold enough of a charge to start the car, replace the battery.
Carl M.
Mar 26, 2021 02:27 PM
Jmoorejr111
Apr 29, 2020 10:07 PM
Alexander2017
Nov 21, 2017 07:31 PM
TayeG35
Oct 20, 2017 09:52 AM
