Maintenance / Repair Help
Old Aug 15, 2008 | 02:02 AM
  #226
ws-6driver's Avatar
the search option is the problem. i searched "repair manual", "maintenance manual", and "technical manual" and came up with nothing of relevance. thanks for the help though.
Old Aug 15, 2008 | 02:12 AM
  #227
ws-6driver's Avatar
Old Aug 15, 2008 | 02:25 AM
  #228
ws-6driver's Avatar
the problem is that i used this web site and several others searching "maintenance manual", "repair manual", and "technical manual" and none of them resulted in relevant items. thanks for the help though.
Old Aug 15, 2008 | 03:33 AM
  #229
skeleton_cru's Avatar
Sedan
ws for three!!!
Old Aug 15, 2008 | 10:25 AM
  #230
DEMoLITIoN's Avatar
help with DD and pioneer d3 install?
Old Aug 15, 2008 | 11:46 AM
  #231
heftylefty58's Avatar
Check out psedog's "Factory Service Manuals" sticky in the FAQ & DIY section:
https://g35driver.com/forums/faq-diy...e-manuals.html
On that note, does anyone know how to enforce literal searches? I tried using quotes like this:
and I also tried this:
"Factory+Service+Manuals"
...but the search results included all threads with any of the 3 words in their title.
Old Aug 15, 2008 | 11:48 AM
  #232
Thumbs up
Never mind--I just noticed the Search Type option at the bottom. Specify Boolean.
Old Aug 16, 2008 | 01:15 AM
  #233
elayman's Avatar
is there a service manual PDF or some sort of thing that outlines how to dissemble every piece? im going to be dynamatting my car and want to get some guides/pictures references
Old Aug 16, 2008 | 03:51 PM
  #234
DEMoLITIoN's Avatar
whats parts do you want to do?
Old Aug 16, 2008 | 04:08 PM
  #235
elayman's Avatar
trunk for dynamat and maybe door/ floor panels
Old Aug 17, 2008 | 03:22 AM
  #236
bmpnride's Avatar
Door panels is a good thing to do. I just had mine done with the audio install and I can really notice a difference. The car is quieter and feels more solid on the doors. The trunk does not really need it much. I was almost positive I would with my sub but it does not really rattle at all. The floor would be overkill unless you are jusr trying to get rid of all the road noise. If that is the case you would need to hit the wheel wells also.
Sorry Eugene...
Lets not get off the topic of the OP.
Old Aug 17, 2008 | 05:26 AM
  #237
elayman's Avatar
can u help me do the doors sometime
Old Aug 30, 2008 | 12:39 AM
  #238
truste307's Avatar
could you tell me the safest method (even just your opinion) to debadge the car by chance.
Old Aug 30, 2008 | 12:49 AM
  #239
Og_Dave's Avatar
Originally Posted by rolltide
Anyone in the Sac/Woodland/Davis area know how to take the clicking out of my goddamn axle?
free lunch & beer....
The Clicking sound from the axle if i remembered had a recall on it, mine did the same thing and i took it too the dealership and was fixed in an hour or so.
Old Aug 30, 2008 | 01:28 AM
  #240
bythabay's Avatar
not 100% sure but this is what I would do:
1)was the car really well
2)heat the badge(s) with a heat gun or similar.. make sure not to overheat.
3)remove heated badge(s).
4)wash again and dry
5)use detailing clay to clean up the mess (I've heard of people having success with products like goo gone also).
6)wash again
7)remove any scratches
8)wax
In any case, read-up on the paint care section to get in-depth experiences and info. good luck!
