odd sounds *need help*
Old Aug 13, 2006 | 07:08 PM
Og_Dave's Avatar
I found a odd sound with my car , it sounds like a wobbling sound coming from the front , my alignment is perfect and my tires have plenty of tread , but when I go about 20 and up mph it has this sound like its wobbling, plus if I let my foot go on the gas and put it under the pedal I feel it somewhat
The car doesn't shake or anything that horrible but it is bothersome and I would like to find out what it is
Can someone tell me what is wrong? My buddy says it could just be the tires but I don't wanna buy a new set of tires if I don't need too.
Old Aug 13, 2006 | 07:29 PM
gizsf's Avatar
Could be tire balancing, loose nuts or a few others. Check to see if any of the little weights have fallen off and that the wheel nuts are tight. Hopefully it's not a suspension issue.
Old Aug 13, 2006 | 07:30 PM
urban's Avatar
To make sure it is not the tires just swap out your front two with a friends and drive around, if it is still there then it maybe something more serious.
Now get back to the kitchen, you have orders waiting
Old Aug 13, 2006 | 10:49 PM
skeleton_cru's Avatar
Sedan
Have you checked the inside tread on your tires? If your toe is off you'll get feathering or scalloping tire wear which will cause a similar sound.
Old Aug 13, 2006 | 10:55 PM
Andy2434's Avatar
David . . . As Eric eluded to, I'd check to see if the wheel/tire combos are still in balance. Perhaps, over time, some of the balancing weights may have fallen off.
Old Aug 14, 2006 | 02:44 PM
Fini's Avatar
what tires do you have? I had a weird sound too when i had the OEM potenzas... sound went away with new tires.....
Old Aug 15, 2006 | 05:56 AM
Og_Dave's Avatar
balanced it 3 times in aweek and had them rotated and what not still has a weird sound
Old Aug 15, 2006 | 05:58 AM
Og_Dave's Avatar
ya i still have the oem potenza's but i still got plenty of tread in the front area hah rear well..... they magically got bald
Old Aug 15, 2006 | 06:00 AM
Og_Dave's Avatar
hahah well now to think of it , i do have a buddy that has a twilight blue g35 thats tt, maybe i can borrow HIS volks and i do mean all 4 volks for a spin
Old Aug 15, 2006 | 06:04 AM
Og_Dave's Avatar
i was under the car today and saw my right tire inside had some feathering
but the driver side tire had non , this will still cause it to have this sound and feel to it
Old Aug 15, 2006 | 10:48 AM
Fini's Avatar
I also had plenty of tread in the fronts too... so i decided to change the rears only... but that gave me VDC problems, and noise was still there... so i had to change out the fronts, and sound went away.
Old Aug 21, 2006 | 01:38 AM
Og_Dave's Avatar
ahhh, im trying to decide right now if i should just get a set of wheels, since the tires for the car is about 1400 just for tires!
but a new set of 19"s with just a wider set up would cost maybe 2900? still it seems like a better choice
also before u changed the tires , was the driving any different for you?
Old Aug 21, 2006 | 11:48 AM
Fini's Avatar
4 Toyo T1R cost around 800 for a little wider tires. i did not notice any difference in driving before i changed my tires. just noticed the noise. the OEM potenzas are really loud compared to the toyos.
Old Aug 23, 2006 | 07:40 AM
Og_Dave's Avatar
damn 800 bucks where did u go to get them
haha my buddy works at les schwab and the best price is 1140 still expensive
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
