Grinding noise when depressing/releasing cluth
Old Aug 7, 2007 | 12:18 AM
fuqxyu's Avatar
Does this mean it's time for a new clutch?
I also hear the same grinding noise at times when i let go of the gas.
The tranny was replaced 6k miles ago, so i don't think it's the tranny.
Any help you guys?
Old Aug 7, 2007 | 01:32 AM
GYAL8R's Avatar
Cali Event Coordinator
BASE ACURA TLX NOW WANT A G35 AGAIN THOUGH
how many miles on your car...?? I'm going to hit 70K original clutch and tranny...
bobby
Old Aug 7, 2007 | 01:46 AM
fuqxyu's Avatar
bobby
63k miles. Not sure if this is the original clutch.
Old Aug 7, 2007 | 10:50 AM
Kris79's Avatar
battle froggy
Any help you guys?
is it slipping at all? when u press the clutch does it make a crunchy noise like your stepping on a bag of chips?
Old Aug 7, 2007 | 11:00 AM
izmir41500's Avatar
G35driver Addict
all the time or right when you start rolling and let off the gas.
Old Aug 7, 2007 | 02:32 PM
fuqxyu's Avatar
It's not slipping at all. It goes into gear pretty smoothly all the time. When i change gears from 1st to 2nd, 2nd to 3rd and 3rd to 4th i hear this metal scraping sound (grind). So it sorta does sound like stepping on a bag of chips.
Old Aug 7, 2007 | 02:33 PM
fuqxyu's Avatar
It only happens sometimes. Only happens when i'm changing gears 1st-2nd-3rd-4th and when i let go of the gas when the car is moving.
Old Aug 7, 2007 | 02:39 PM
izmir41500's Avatar
G35driver Addict
do you know the sound of the ABS test? it only happens when you first start running. if you go to 10 mph and let off there is a grinding noise, then it doesn't happen after that.
Old Aug 7, 2007 | 04:43 PM
fuqxyu's Avatar
It happens not only around 10mph letting off the gas, but also when i'm speeding up and shifting fast. It doesn't make a sound most of the time when i shift slowly.
Old Aug 11, 2007 | 05:18 AM
G-MENTED's Avatar
i think youre referring to the "normal" grinding from the transmission.
Old Aug 14, 2007 | 12:50 AM
fuqxyu's Avatar
Whoa, are you serious about the "normal" grind from the tranny? It gets pretty annoying if i don't have my music up.
Marlin84
Apr 1, 2020 12:52 PM
magnetism80
Feb 1, 2019 10:00 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
