High Engine Oil Consumption Rates
Old Mar 23, 2008 | 11:14 PM
  #226
Andy2434's Avatar
At the mileage, which you have indicated, you are good to go. I would have loved to have your oil level readings at that said mileage.
Old Mar 23, 2008 | 11:25 PM
  #227
awong's Avatar
u got high OC, so wat do you do, you just keep on adding more oil?
Old Mar 23, 2008 | 11:30 PM
  #228
Andy2434's Avatar
Did my car experience high OC? Yes, it did. I started this thread.
Old Mar 23, 2008 | 11:40 PM
  #229
awong's Avatar
just wondering u resolve the problem or still happening
Old Mar 24, 2008 | 12:03 AM
  #230
Andy2434's Avatar
The jury is out for the next 2500 miles. Did you read the entire thread?
Old Mar 26, 2008 | 02:43 PM
  #231
SaintRedRocket's Avatar
My G35 in a 2004 and is apparently eating oil quickly. The car had 40,600 miles on it for it's latest oil change. The technician at PepBoys said that only 1 quart drained out. I haven't had the time to make an appointment with a dealership yet with my travels. The last oil change was around 36,000 miles. I did not know that this engine had such a bad consumption problem until I found this webpage.
Is this a TSB recall or is it a 4 year/70k drivetrain warranty issue? I purchased it in early March of 2004, so I'm pretty sure my warranty is now up? Just want to see how well prepared I'll need to be when I take it to a dealer as far as TSB vs. warranty. I can actually smell oil burning while driving.
Old Mar 26, 2008 | 05:32 PM
  #232
Kris79's Avatar
battle froggy
1 qt or 4k miles is not bad. these guys are doing 1 qt every 1k
edit misread ur post.
but damn.... thats alot for a 04!
Old Mar 26, 2008 | 05:41 PM
  #233
ICANHASFRANKIE's Avatar
Nope, its more like 4 qt, cus "only 1 quart drained out".
Old Mar 26, 2008 | 05:42 PM
  #234
How often you check your oil? you might want to monitor it closely.
Old Mar 26, 2008 | 06:09 PM
  #235
Andy2434's Avatar
So, in other words your engine consumed some 4 quarts of oil in approximately 4,600 miles. Hmmm, that's about 7/8ths of a qt. per every 1,000 miles. According to the old Infiniti consumption standards, you are borderline. However, according to the new TSB Oil Consumption Standards, your engine is definitely consuming oil.
There are 2 issues, here. The first and most important is that the TSB OC standards have been set for the engines, which are year models 05 to 06 and those equipped with a 6MT. Second, your car may be out of warranty.
Moving along . . . Your car will most likely not qualify for an engine replacement per the new OC standards for the reasons, which I have stated. However, if your car is still within its warranty period, extreme OC should and will be warranted. It will be an uphill struggle with the dealer though. The first thing they will ask for is your previous engine oil change records. Many engines have been exchanged that were model years other than stated due to OC issues.
There is no telling when your engine oil level reached the low of 1 quart during the past 4,600 miles. I trust that it was recent. With that little amount of oil remaining, permanent damage is a strong possibility.
Take your car into the dealer and discover what your options are, if any. Do not wait. First, establish whether or not your car is still within its warranty period. Good luck to you.
Old Mar 26, 2008 | 06:47 PM
  #236
Thanks for all of the information. Can Infiniti dealers look up all oil records from other Infiniti dealers? I've only had 3 non-Infiniti dealership oil changes and two of those times were at a Nissan dealer; third being at PepBoys this last time. The two times I had to go to the Nissan were because my dealership was booked "for 2 weeks" and I needed to get it done before a long business trip.
The check oil light kept coming on and off and I threw a misfire code, so I stopped into PepBoys to see if they could change it real quick since it's always a long wait at the dealer. I was taken back by how bad it had gotten. They did not want to check oil consumption in August when I asked the previous dealer to do it saying that it was just the transmission.
The problems with my G35 have been very disappointing. If is isn't one thing, than it's another. I've been averaging at least one trip to the dealership for warranty service every month for the past 2 years excluding the past couple of months.
Old Mar 26, 2008 | 08:36 PM
  #237
Andy2434's Avatar
Yes, all of your Infiniti service records are in the database and can be viewed by any Infiniti dealer. I go to Nissan for oil changes, as well. Just be sure to have all of your non Infiniti oil change paperwork handy.
Old Apr 10, 2008 | 12:25 PM
  #238
accordhybrd's Avatar
I take the car in tomorrow to have the oil level checked. This is the first check on the V2 engine. I will update everyone tomorrow when I get back from the dealer.
Old Apr 10, 2008 | 02:30 PM
  #239
bythabay's Avatar
Originally Posted by V35 Skyline GT
You can't check yourself?
Anyway, give us the 411 when you know. Hope she's a winner.
haha.. I see an new DIY vid on the horizon..
"DIY: Check your oil"
Old Apr 10, 2008 | 04:47 PM
  #240
I could check it myself, but this is my first oil level check for oil consumption on my V2. When I took the car in to begin the test I was 3/4 of a qrt low. We will see how much I have burnt since.
BTW the dip stick is sealed so it can't be tampered with.
