Various Dyno Result
Old Jan 27, 2008 | 04:10 PM
eipracing's Avatar
Various Dyno Result
Sup guy
After I cleaned up my dyno database, I would like to share some of the base and mod pull from different cars.
Old Jan 28, 2008 | 12:40 AM
vodkarocket's Avatar
Modded Member
Your dyno seems to read abnormally low. Guess it doesn't matter when you're tuning the vehicle on the actual dyno, but...
Old Jan 28, 2008 | 12:43 AM
Kris79's Avatar
battle froggy
whats the point of this thread showing cars not g's?
but i am with vodka on this one even low for a mustang dyno, only thin g i can think of is cheating the numbers to make tuning loook like u gain more than u really do.
Old Jan 28, 2008 | 06:35 PM
dofu's Avatar
20 Year Member
Actually, it matters. Tuning on a low reading dyno is much better than tuning on a higher reading dyno... the numbers are more realistic since dynapacks and most other dynos don't compensate for as much.
There is a G in there... stock base run though. I'll post up my after dynos in a bit after I get a chance to dyno my car on a dynapack or dynojet to show you guys the difference between this dyno and others. There are a few shops I need to hit up first to see who will let me dyno for free! And for cheating numbers... yea, 207 looks really great for a G...
Old Jan 28, 2008 | 07:38 PM
urban's Avatar
Them numbers do seem low for an 05 G35.
Here is one for an 04 G35 completely stock on a mustang dyno also.
https://g35driver.com/forums/tuner-dyno/194739-bone-stock-04-g-6mt-dyno.html
232rwhp 227rwtq
Old Jan 28, 2008 | 10:24 PM
Mad Paradox's Avatar
J-Dizzle
I did a base line dyno with XS Engineering, drum type dyno and my car got 247 rwhp and 231 rwtq. Honestly, I don't know why they would even make the two different types of dynos, wouldn't it better if you could just have one kind and get the "real" accurate results. Whether your car puts out 197 hp on this dyno or 250 on another dyno your car is still stock. Never really understood why they did that...
Old Feb 14, 2008 | 01:24 AM
eipracing's Avatar
yes you are right about this, on the mustang dyno they call it weather station which will affect the reading with different out side atmosphere. this funtion you can enable or disable it
nice 2 talk to u 06CPV35!!!
Originally Posted by 06CPV35
Mustangs have always been known to read low, which is fine when tuning and comparing gains from tune and/or mods from stock baseline of same vehicle ideally on same day.
As you all know as well, temp, humidy, standard or SAE corrected affect numbers too and not disclosed on those charts.
That G was probably Dynoed on a very hot day with very low humidity is my guess for those low numbers.
Thanx for sharing those btw...
Old Feb 14, 2008 | 01:48 AM
dofu's Avatar
20 Year Member
It's all in the way they set up their dyno... you can make a Mustang read just as high as the others if they weren't compensating for as much like weight, temp, humidity, etc...
Thebaws11
Nov 30, 2016 12:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
