VDC, RAS, SLIP lights on & off for no reason
Old Jul 6, 2008 | 05:01 PM
Kimochi543's Avatar
Hi,
Over the last couple of months, the VDC, RAS, SLIP lights would come on after I start the car. I turn off the car and turn it back on after counting to 10 (why 10? I don't know). The lights would be off. There is no apparent reason why this is the case. Most people with the similar problem on the forum were either driving hard or had after-market parts put it. My car is stock and I don't do "spirited driving."
Couple of times, after I turn off the engine, it would not start. I count to 10, tap the accelerator a few times (again, no idea why I do this), and it started again with the VDC, RAS, SLIP lights would be off.
I took it to Frontier Infinity and after some diagnostic and a 20-mile test drive, I was told that they found nothing and send me on my "merry" way.
I searched the forum. It would appear the problem is with either sensors or low brake fluid. Wouldn't the dealer find sensor problems on the diagnostic and a simple visual inspection should detect the low brake fluid problem.
Help!!!!
Derek
Old Jul 6, 2008 | 09:19 PM
My Key's Avatar
Could also mean that your brakes are almost gone...
My rear pads were almost gone and I had to go get them changed...
Old Jul 6, 2008 | 09:29 PM
berniEE's Avatar
same mines came on n off jus like yours i replaced my brakes and they were gone. check ur brakes =]
Old Jul 7, 2008 | 10:47 PM
Kimochi543's Avatar
thanks, I will definitely have the dealership check this. why dealer? It's because I am worse than useless when it comes to checking/fixing cars.
Old Jul 7, 2008 | 10:49 PM
rookie's Avatar
Check your brake fluid as well.
Old Jul 7, 2008 | 11:24 PM
Kris79's Avatar
battle froggy
^^^ i would check that.
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
