Best And Worst Mods
Feb 19, 2009 | 04:00 PM
  #61
^^ just rev your engine
Reply 0
Feb 19, 2009 | 04:16 PM
  #62
Non rev ups are 03-05 I believe. Rev-ups are 06+ models.
Reply 0
Feb 19, 2009 | 04:41 PM
  #63
Quote: ^^ just rev your engine
lol
Reply 0
Feb 19, 2009 | 06:47 PM
  #64
Quote: Non rev ups are 03-05 I believe. Rev-ups are 06+ models.
Eh... ok! It doesn't quite work like that, but if that's what you like to believe.. then it's fine with me...
Reply 0
Feb 19, 2009 | 06:52 PM
  #65
Quote: I was thinking about the same combo of 5/16 ISO term - spacer and MREV2.
People are saying, in order to install MREV2, you will need a revup engine. How can you tell if you have a revup engine?
http://lmgtfy.com/?q=how+do+i+know+i...ev+up+motor%3F
Reply 0
Feb 19, 2009 | 06:55 PM
  #66
03-04 all are non rev up, 05+ 6mt are rev up, 05+ auto are non rev up.
Reply 0
Feb 19, 2009 | 06:57 PM
  #67
cusco sways + spacer + intake and pocket the rest
Reply 0
Feb 22, 2009 | 10:40 PM
  #68
Quote: 03-04 all are non rev up, 05+ 6mt are rev up, 05+ auto are non rev up.
soo.. what you are saying is the mrev manifold wont work on a 03 g35 coupe?
Reply 0
Feb 22, 2009 | 10:49 PM
  #69
Quote: soo.. what you are saying is the mrev manifold wont work on a 03 g35 coupe?
No, it will not work. The MREV is essentially the very same lower collector as the OEM non revup lower collector, bar some minor changes.
Edit: With regard to Motordyne products, your best bang for the buck is a plenum spacer.
Reply 0
Feb 22, 2009 | 11:01 PM
  #70
Quote: No, it will not work. The MREV is essentially the very same lower collector as the OEM non revup lower collector, bar some minor changes.
and for the plenum spacer wat size 1/2"? and what kind Copper Iso Thermal, Iso Thermal, or Basic?
Reply 0
Feb 23, 2009 | 12:02 AM
  #71
Go with a 5/16's Iso Thermal. Personally, I did not install the coolant control valve supplied with the Iso Thermal.
Reply 0
Feb 23, 2009 | 02:46 AM
  #72
Would removing that large metal piece in the middle of the exhaust with a straight pipe increase power at all? (Sorry, I don't know what that piece in the exhaust is actually called. I believe it is behind the cat tho.)
*edit*
This piece:
Reply 0
Feb 23, 2009 | 02:55 AM
  #73
thats a mid pipe, just get a coupe one it will make the car sound better but wil not give u anymore hp. but it wil be lighter
Reply 0
Feb 23, 2009 | 09:50 AM
  #74
Sorry Andy, but it will work and give any VQ motor gains. It just won't make as much gains as on a revup, making it less of a bargain of a mod.
Quote: and for the plenum spacer wat size 1/2"? and what kind Copper Iso Thermal, Iso Thermal, or Basic?
Most people stick with 5/16, but I'm not sure which makes more power on a non revup... In CA, you can go with either throttle body coolant bypass, but the copper iso is automatic for extreme cold temps.
Reply 0
Feb 23, 2009 | 11:41 AM
  #75
Most with non revup just do spacer (5/16th).
Agree MREV2 on non revup = not real good gains/$ ratio. There's some, but not a clue how much either.
I believe Motordyne gives $100 bones off MREV2 price when you send in your oem non revup collector as a core exchange.
Us revup peeps don't get that b/c Motordyne doesn't want ours.
Reply 0
