Smog Test Recommendations - Penninsula
Old Dec 31, 2009 | 03:17 AM
bmpnride's Avatar
Can anyone recommend a good place to get a smog test done on the Penninsula? I dont have much engine work done but I also dont want to take it somewhere that will hastle me any with the polished stuff I have, even though it does not change the engine in any way. Thanks...
Old Dec 31, 2009 | 11:34 AM
bigc's Avatar
Wings Nation
if you're willing to drive a bit, you should PM LeMansZCa in this thread:
http://my350z.com/forum/northern-cal...-san-jose.html
Old Dec 31, 2009 | 12:43 PM
ntrinsik's Avatar
Don't go to Quik Smog in Mountain View.. On my previous car, they questioned every single modification I had done, called CARB on all the E.O. numbers, and failed me the first time cause one of the CARB numbers was numbered incorrectly (# for an '02 when mine was an '03, but the '02 was a completely different motor and part). I came back with the correct CARB sticker and they still had issues with it because I put the sticker on the firewall instead of on the part.
Old Dec 31, 2009 | 01:44 PM
bmpnride's Avatar
Thanks for the input so far. If I remember correctly, a carb sticker is no longer required for the pop charger.
Old Dec 31, 2009 | 06:55 PM
35gsleeper's Avatar
beshoff
Old Jan 1, 2010 | 10:39 AM
V35 Skyline GT's Avatar
6MT Coupe
Originally Posted by bmpnride
.... If I remember correctly, a carb sticker is no longer required for the pop charger.
Didn't know that, but I'd still sport it if you have it. Mine came with one. I thought any mods from intake to cats req CARB approval for Cali. I'd put your stock plenum cover on to hide that spacer too.
Old Jan 2, 2010 | 03:50 PM
toyotabike's Avatar
Check your message OP.
Old Jan 2, 2010 | 10:46 PM
35gsleeper's Avatar
beshoff is the way to go. They support modified cars and will smog it.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
SupermanGPS
Sep 19, 2015 01:42 PM
Danielek
Sep 18, 2015 12:16 PM
lag35driver
Northern California
Sep 17, 2015 12:32 PM
Detailed Image
Sep 14, 2015 07:30 AM
