rear camber arms bushings
Old Mar 22, 2010 | 10:17 PM
g3fly's Avatar
Anyone knoe where I can buy new bushings for the rear aftermarket camber arm's? the rubber completly wore out one side. That was the reason for baaad tread wear on my tire and a anoying squeaking noise. I want to fix it asap before new tires go on the G! HELP PLEAAASE! lol.
Old Mar 22, 2010 | 10:32 PM
WTF??'s Avatar
I think beshoff should be able to help you andrew
I dont think they give the driver discount anymore though
Old Mar 22, 2010 | 10:36 PM
g3fly's Avatar
no more 10% off? owell. Ill call and find out.
thanks Mike hella forgot about them
Old Mar 23, 2010 | 12:41 AM
G35Papa's Avatar
Do you have stock arms? If so, i have a set you can have. Just need to come get them.
If you want to get aftermarket bushings, you can get them here
http://www.jscspeed.com/catalog/Niss...initi_G35.html
You can use this site to reference diagrams of the suspension components.
https://www.infinitipartsonline.com/...upe-parts.html
Old Mar 23, 2010 | 08:24 AM
g3fly's Avatar
naah Chris I got aftermarket adjustable camber arms. I bought them of another member here on driver I think there Stillen
Old Mar 23, 2010 | 11:17 AM
G35Papa's Avatar
Ok, then you might want to consider getting the aftermarket bushings cause they're made of polyurethane so they won't rip again like the rubber ones. The only thing I'm not sure of is if they will fit an aftermarket arm. I think they would but not sure.
Old Mar 23, 2010 | 01:00 PM
gabe3d's Avatar
What camber arms do you have on the rear?
Though mine didn't wear out, I did run into this same dilemma. I wanted to buy some poly bushings to put into my Ichiba arms but I couldn't confirm with anyone whether the diameter of the hole was preserved. As oppose to guessing I just bought new camber arms from SPL.
Old Mar 23, 2010 | 11:32 PM
g3fly's Avatar
I forgot what they were and I just went thru my PM's and didnt find the ones from when I purchased it. If I measure it and get a size where can I buy the poly's?
Old Mar 23, 2010 | 11:35 PM
g3fly's Avatar
Found this....
The "Pivot Bushings" should work right?
http://www.prothane.com/universal.ph...f0d436a9911c29
Old Mar 24, 2010 | 01:20 AM
gabe3d's Avatar
http://z1auto.com/prodmore.asp?model...ng&prodid=4573
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
rezendvous420
May 31, 2020 01:26 PM
TreeFiddy
Aug 10, 2015 06:50 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
