Other Regions United Kingdom, Japan, Australia, Middle East, Asia
any G35 in europe??? --> the GAS question!!
Old Apr 1, 2006 | 06:15 AM
1stG35inCTRY's Avatar
Helo, happy G owners in europe... i just wanna know about what gas to use and, please support your answer... because as we all know in usa they use gas with an octane of 91... but , for example, in Latvia we have gas ranging from 76 up to 98.... 95 and 98 being the most commonly used...
Old Apr 7, 2006 | 02:31 PM
speedraver's Avatar
wassupMyNinjas! (^_^)
I guess you're the only one in Europe bro! Show some pix of your ride!
Old Apr 11, 2006 | 08:23 PM
Zouk's Avatar
There are a few G35's in the UK.
Also, how they rate fuel in Europe is different from how they rate fuel in the US. Basically, Europe uses a RON scale and the US uses a PON scale. Therefore, a rating of 91 in the US is equivalent to a 95 in Europe. It's a common mis-conception that the US gets inferior fuel to Europe.
There's not much point in using 98 gas unless the ECU is tuned to it unless you want the better cleaning properties of gas such as Shell Optimax.
Old Apr 12, 2006 | 12:06 PM
aequitask's Avatar
so are the g35's in europe rhd then straight from japan or what..are they still called g35s there?
Old Apr 12, 2006 | 05:00 PM
Zouk's Avatar
In UK anyway they are from Japan, so they are badged under Nissan as Skyline 350GT.
Old Apr 13, 2006 | 09:47 AM
as far as Latvia, we import Infinitis from USA.. so it is the G
Old Apr 18, 2006 | 04:06 AM
thanks for the clarification, I did not know about it, thanks.... I will stick to 95 octane
Old Apr 21, 2006 | 05:26 AM
gregthay's Avatar
In the UK, we get the *** version so its a Nissan Skyline 350GT - which confuses people as we also have a Nissan 350Z-GT in large numbers!
I always use RON98 (Super Unleaded) - Shell Optimax for example as in Japan they tend to use higher rated fuel.
Old May 17, 2006 | 09:20 PM
Romulus's Avatar
Florida G35 Club, Premier Member
Do you have any pics of a Latvian G? How do they do with the large Euro license plates?
Old May 19, 2006 | 05:02 PM
unsat_rbd's Avatar
how much is fuel per gallon out there in the UK? I might be moving out to the UK or Germany next year and want to know if I should bring my G out there. Anyone have a US G out in Europe?
Old May 25, 2006 | 08:32 AM
gregthay's Avatar
Fuel in the UK at the moment is expensive compared to you guys in the USA. Based on the fact that its just under £1 / litre - a gallon is about £4.30 = around $7.50 or thereabouts. I only get through a tank of petrol a month in my 350GT which isn't too bad. If you planning to do loads of miles, then I wouldn't bring the G unless you got some decent funds!
All the G's in the UK are imports from Japan (hence called 350GT) as we drive "on the other side". In Europe they will be US G's.
Old Jun 8, 2006 | 02:51 AM
sixthGear's Avatar
I just moved from the UK, can't imagine G's over there.... prob. turn A LOT of heads!!!!
Old Jun 19, 2006 | 08:05 AM
here we go... this is a temporary license plate...
in order to get a permanent there is a whole bunch of things to go thru.... paperwork AND money!!
Attached Thumbnails any G35 in europe???    -->  the GAS question!!-image001.jpg   any G35 in europe???    -->  the GAS question!!-image100.jpg   any G35 in europe???    -->  the GAS question!!-image007.jpg
Old Jun 19, 2006 | 06:27 PM
Scootch's Avatar
wat part of uk u from i was just there for new years have many friends n im also in a car club in the uk called underground styling aka ugs
Old Jun 19, 2006 | 06:43 PM
as you can tell from the license plate it says "LV" and that means LATVIA
