Jack Stands and the G
Old Sep 18, 2013 | 02:54 AM
  #241
Big Booty Trudy's Avatar
So what is the best alternative? Hope it's not necessary to read 16 pgs.
Old Sep 18, 2013 | 05:52 PM
  #242
TORETTO's Avatar
I usually put jack stands under my oil pan.
Old Sep 18, 2013 | 06:19 PM
  #243
I think I commented in the wrong thread. Looking for a solution to jacking up the car, literally. My jack doesn't fit that slot correctly. Hockey puck method the best?
Old Sep 18, 2013 | 06:36 PM
  #244
TORETTO's Avatar
You can jack the car up anywhere on that pinch weld, although technically you're supposed to slide the jack further in and jack it from the frame. But with lowered cars, you don't really have a choice. And the shop lifts use the pinch welds as jacking points as well.
Jack the car via the pinch weld and place a jackstand on that pinch weld. Preferably in the slotted area.
Old Sep 18, 2013 | 06:42 PM
  #245
TORETTO's Avatar
If I just have to jack up the rear portion, I go by the rear differential. And place jack stands on the pinch welds. You need one of those extra long low profile jacks to reach the rear diff if you are lowered.
  #246
Yeah but my problem is that my jack has that rounded face. It doesn't fit the weld nice and snug. It just picks up the whole underside of my skirts. Idk if I explained myself correctly.
Old Sep 18, 2013 | 06:43 PM
  #247
TORETTO's Avatar
Pic of jack?
Old Sep 18, 2013 | 06:47 PM
  #248
TORETTO's Avatar
If the saddle is round, that's the same for almost all jacks out there. Look under the car and make sure the pinch weld is centered on the saddle of the jack, and begin jacking it up. The sideskirts do not go far enough inwards to get in the way. Unless you have aftermarket skirts. But I've worked on G35s with aftermarket skirts, and they still don't go far enough in to get in the way. If your skirts do, you can just trim a portion for the saddle of the jack.
Old Sep 18, 2013 | 06:48 PM
  #249
Alright thanks man. I'll see if I can move it around and not damage anything.
Old Sep 18, 2013 | 06:51 PM
  #250
TORETTO's Avatar
Like this. Yes the pinch weld will probably get bent without a pinch weld adapter for your jack, but whatever.
Old Sep 18, 2013 | 06:53 PM
  #251
Ok! That's what I was trying to figure out. I thought it was bad if it got damaged.
Old Sep 18, 2013 | 07:00 PM
  #252
TORETTO's Avatar
You can put a puck or maybe even some microfiber cloth on it and see if that doesn't bend it. But since it's something nobody can see, I don't care if I bend it. And I don't switch jack points all the time. I bent one spot, and I just keep jacking from that spot every time.
Old Sep 18, 2013 | 07:03 PM
  #253
Lol ok. That's what I've been doing too.
Old Sep 18, 2013 | 07:52 PM
  #254
guitarrocker98's Avatar
Mine are bent. Use the pinch welds. My cars been on jacks for about 4 months now. No issues whatsoever. Pinch welds are the way to go.
Old Sep 18, 2013 | 08:00 PM
  #255
bigc's Avatar
Wings Nation
Put a hockey puck on the saddle ("the rounded face") - you can cut a small slot in it if that makes you comfortable. That will give you enough clearance so that the saddle isn't putting weight on the side skirt when you jack up the car.
