Jack Stands and the G
Old Aug 7, 2006 | 10:48 PM
  #31
x7original4x's Avatar
you should definetly make dem
Old Aug 7, 2006 | 11:52 PM
  #32
OH6 G35's Avatar
Guys...I've been pondering the idea but it basically boils down to a "liability" issue. I am certainly confident that, under the "right" conditions, they work great (I've been using them lately, quite often) but...
Old Aug 8, 2006 | 02:03 AM
  #33
imalazeeass's Avatar
put a disclaimer
Old Aug 8, 2006 | 09:25 AM
  #34
OH6 G35's Avatar
I wish that was the answer !
...I'm sure that it's much more complicated than that.
Old Aug 8, 2006 | 03:21 PM
  #35
i was wondering, what if i used a piece of 2x4 to make something similar? Would it hold up strong enough? What are the dimensions of your block?
Old Aug 8, 2006 | 10:36 PM
  #36
OH6 G35's Avatar
I would be a little "concerned" if you used a piece of wood. Especially where the pinch-weld goes into the groove ! This would be the place where the wood may split !!
Old Aug 9, 2006 | 04:12 AM
  #37
ahh good call
Old Aug 9, 2006 | 04:19 AM
  #38
abcquackyxyz's Avatar
awww. sucks. i would love a set of those aluminum blocks.. You should really consider pitching it so that you can get it mass produced.
Old Aug 9, 2006 | 07:44 AM
  #39
skeleton_cru's Avatar
Sedan
Originally Posted by OH6 G35
...some additional pics !
I made the same thing with wooden blocks and they work fine.
Old Aug 9, 2006 | 09:38 AM
  #40
OH6 G35's Avatar
I'm really thinking about doing this project now !
Can this fly ???
Old Aug 9, 2006 | 09:53 AM
  #41
trey.hutcheson's Avatar
Here's a suggestion: do some research by visiting a nissan and infiniti lot. Take your blocks with you. If they fit the z, maxima, m, or anything else, then you've got a pretty large market.
Old Aug 9, 2006 | 10:06 AM
  #42
Sedan
Old Aug 9, 2006 | 12:22 PM
  #43
OH6 G35's Avatar
Looks pretty good !
Nice Job !! ...just be careful...
Old Aug 9, 2006 | 08:22 PM
  #44
man having aftermarket sideskirts is a pain! I cant find a way to jack up the front. I tried going up on 2x4's.. not high enough for jack. I thought about getting ramps, but bumper is too low. I'm going to try to go up on 2 stacked 2x4's and see if that works. If not, im gonna have to jack up the rear, use jack stands, and work my way to the front. PAIN! Just to change front rims! AH!
Old Aug 9, 2006 | 08:49 PM
  #45
MD_V35's Avatar
You should try looking up these low profile ramps. I have them and they work really well.
http://www.jhpusa.com/catalog/produc...51fcce0b5ab565
