Engine Bay Pics*Post here*
Old Jan 7, 2011 | 09:42 AM
  #2161
Swivel's Avatar
Moderator
Marcus, you gotta ditch those green ARC caps, they don't go with your theme at all. Send them to me naow!
Old Jan 7, 2011 | 10:58 AM
  #2162
LordFappington's Avatar
I believe with that intake the MAF is underneath, thats the furookie isnt it?
Old Jan 7, 2011 | 11:26 AM
  #2163
CandlestickPark's Avatar
ill Sedan
Originally Posted by nemesys6
NOOB question... What happened to the MAF?
The MAF is plugged in on the underside of my intake. Its a FuRookie intake, a limited run of these were made.
No way....LOL! ARC power!!
Old Jan 13, 2011 | 01:18 PM
  #2164
CERBERUSlucid's Avatar
Not a G but I owned one once… I miss this site =)
here is my Z though, still a work in progress...overflow tank was done by G35drivers SxExCx!
Old Jan 13, 2011 | 01:22 PM
  #2165
2GoRNot2G's Avatar
Lookin' good! Now you need Sean's (SxExCx) matching power steering tank.
Old Jan 13, 2011 | 01:24 PM
  #2166
SxExCx's Avatar
^we need to tuck those wires too!
Old Jan 13, 2011 | 01:41 PM
  #2167
Zelllllllllllll's Avatar
Originally Posted by PhantomIPG
Here's what's in those "bundles"!
Take your time and be very careful!
...and what it'll look like when your finished!
that looks so good, good job
Old Jan 13, 2011 | 01:57 PM
  #2168
Frankieg35's Avatar
To u guys that did a wire tuck where did u drill through the firewall for the battery cable?? Me and my buddy are doing it but his motor is out and we dont wanna run it near where his headers are gonna be.. thanks!!
Old Jan 13, 2011 | 02:26 PM
  #2169
SxExCx's Avatar
^there is a big square hole right below the hard coolant pipe the leads to the battery compartment. You just need to drill a small hole under the battery tray to pull it through.
Old Jan 13, 2011 | 03:13 PM
  #2170
Frankieg35's Avatar
Ok kool thanks bud!!
Old Jan 13, 2011 | 07:44 PM
  #2171
Already saving for it…
AND YES!!! In need Desperate need for a wire tuck!!!
Old Feb 6, 2011 | 12:36 AM
  #2172
856_reilly's Avatar
Does anyone know whats gotta be done when you want to run braided lines and the hose slides on to a connection that is just a slide on. For example the line that is under the intake that connects both valve covers. The hose slides on the plastic fitting and I'm not sure how to put a polished AN fitting to make it look clean. Also there is a brake (vac) line that connects into the intake. ( hose slides on the intake) Any help would be great.......
Old Feb 6, 2011 | 12:42 AM
  #2173
ill Sedan
^I (and others) use Earl's hose clamps
Old Feb 6, 2011 | 12:57 AM
  #2174
Frankieg35's Avatar
Ok but when u slide the fitting on how do u clamp it down?? Am I missing something??
Old Feb 6, 2011 | 12:59 AM
  #2175
bigc's Avatar
Wings Nation
the earl's clamps have a worm clamp concealed underneath.
