Engine Bay Pics*Post here*
Old Nov 29, 2008 | 05:23 PM
  #556
bigc's Avatar
Wings Nation
they'll look good if you have other gold accents
Old Nov 29, 2008 | 06:27 PM
  #557
DrewTheSuit's Avatar
^^^^under the hood just my heat shield on the popcharger is gold, but wheels/brakes will be gold eventually
Old Nov 29, 2008 | 07:34 PM
  #558
SxExCx's Avatar
^I say do it. If you have a richie or NRG strut bar, the mounting brackets are goldish
Old Nov 29, 2008 | 09:08 PM
  #559
marcellsr's Avatar
Originally Posted by Boston
You also need to use M6 cap bolts. The OEM or MD bolts are standard hex head bolts.
Yes they're M6 Socket Cap bolts, take a look at the MD instructions, you'll need in length, 4 70mm bolts and 3 55mm bolts. I also plan on going around the perimeter of the Plenum with 35mm bolts, take a look at the washers i'll be using. Got this URL from another member on here.
http://passwordjdm.com/PasswordJDM-F...P1997C325.aspx
Old Nov 29, 2008 | 11:51 PM
  #560
Roguewolf's Avatar
any tips on how to wash engine bay? mine is FILTHY!!!
Old Nov 30, 2008 | 02:01 AM
  #561
CandlestickPark's Avatar
ill Sedan
A good DIY is posted here:
https://g35driver.com/forums/repairi...sorry-56k.html
Old Dec 8, 2008 | 02:09 AM
  #562
ill Sedan
Latest mods to my engine bay:
1. ARC Oil Catch Can with custom RareJDM bracket (so the can sits in the middle) and Earl's braided hoses and fittings - Big thanks to Dave (OH6 G35), Zack (zackt69) and Gabe (damineg35) for fabricating the bracket and installing the catch can. It was fun hanging out this afternoon.
2. Pi-Thon Polished A/C Line Caps
3. Removed passenger side windshield wiper (thanks Chris - bigc for the suggestion!)...drivers side will be removed in the Spring (it never rains in SoCal)
Up next:
1. RareJDM main engine harness cover
2. Paint the reservoir tanks black
3. Polished timing cover install
Old Dec 8, 2008 | 02:12 AM
  #563
hyperlite21's Avatar
looks great marcus, i wish i could afford the catch can, ive always wanted the arc one
Old Dec 8, 2008 | 02:13 AM
  #564
ill Sedan
^Thanks Mike. I got the catch can used in the Marketplace, still cost a grip though. The Earl's braided hoses and fitting broke the bank too.
Old Dec 8, 2008 | 02:14 AM
  #565
Beebo's Avatar
Damn marcus looks sick
Old Dec 8, 2008 | 02:22 AM
  #566
ShanesG's Avatar
looks sick marcus, did you hear about my brakes, I can't depress the pedal, I donno if it's from putting the hose locks on
Old Dec 8, 2008 | 02:25 AM
  #567
ill Sedan
Thanks Shane. I haven't been on driver most the day today so I hadn't heard about your brakes. Which hose lock would have done this to your ride, I guess there is one with the valve in it but I just read in your thread that you checked that ...weird??
Old Dec 8, 2008 | 02:28 AM
  #568
ShanesG's Avatar
that 1 under the heater hose.... I'm thinking I donno though, unless my master cylindr or brake booster failed just like that
Old Dec 8, 2008 | 04:25 PM
  #569
ShanesG's Avatar
So i fixed the brake problem, i just had that heater hose on the wrong way....i didn't know it was a 1-way hose...anyways here's a pic fron today. just need those caps and radiator locks!
Old Dec 8, 2008 | 04:31 PM
  #570
Boston's Avatar
^and a polished TB.....
