Engine Bay Pics*Post here*
Old Apr 9, 2009 | 11:47 PM
  #1126
k67p67's Avatar
It looks like some are going through a lot of work to "tuck" the main engine harness. Why not tuck it behind the motor where it's less visible? It's a little bit more work but I think the results are worth it. Additionally, dont' the fuel rails get pretty hot? I've seen several pics where the main harness is run very close to those rails. It wouldn't be pretty if the split loom melted away and the wires got BBQ'd.
Old Apr 10, 2009 | 12:00 AM
  #1127
G35Papa's Avatar
Hey K67 (sorry, forgot your name ) does the tuck behind the engine also involve cutting/sodering the wires as well? I did a similar tuck as shown in the pic above and have also seen the tuck next to the fuel rails as you have just described. Basically, I'm looking to tuck without having to cut if possible.
Old Apr 10, 2009 | 12:02 AM
  #1128
hyperlite21's Avatar
i actually put mine as far away from the rails as possible but as far up so you couldnt see the wires w/the plenum on, ill take some close up but the wires are in a pretty safe spot right now, although i need to get back in there and move some wire around cuz i didnt like how it turned out in the back left, obviously you cant see that part but im gonna re-route some stuff back there to make it more clean.
Old Apr 10, 2009 | 12:06 AM
  #1129
keff108's Avatar
CandlestickPark what intake tube are you using. Is that like an Injen maybe? It looks good.
Old Apr 10, 2009 | 12:08 AM
  #1130
G35Papa's Avatar
Candlestick is running a Fujita intake
Old Apr 10, 2009 | 12:10 AM
  #1131
keff108's Avatar
Thanks G35papa.
  #1132
CandlestickPark's Avatar
ill Sedan
Yup, Fujita with an Amsoil filter.
Old Apr 10, 2009 | 12:25 AM
  #1133
Wannabe6MT's Avatar
-MN G Crew-
Guess i can contribute now with a half way decent lookin' bay.
Old Apr 10, 2009 | 12:28 AM
  #1134
SxExCx's Avatar
^polished plenum and TB?
Old Apr 10, 2009 | 12:39 AM
  #1135
k67p67's Avatar
Tucking behind the engine requires some minor extending/rerouting of wires (mainly ground wires and coil pack wires). If you see pics of the cleanest VQ engine bays, you'll see that the wiring in and around the coil packs and injectors has been cleaned up (extended/rerouted/sleeved). It's more of an issue with aftermarket plenums like Cosworth or Kinetix SSV but can still make a difference with an OEM plenum. Just be careful not to mess with the wiring for the TB or the MAF. Those wires are shielded and do not take kindly to being cut.
Old Apr 10, 2009 | 12:55 AM
  #1136
G35Papa's Avatar
Thanks for the info...appreciate it. I'm going to be taking a closer look on the work needed to get this done and probably go for it. I'll have a better idea on what I need to do once I take everything off again. Thanks for the tips and warnings. Good info.
Old Apr 10, 2009 | 12:57 AM
  #1137
keff108's Avatar
Sean I think he needs a grounding kit too. Click my sig.
Old Apr 10, 2009 | 02:18 AM
  #1138
SxExCx's Avatar
^word
Old Apr 10, 2009 | 05:36 AM
  #1139
ShanesG's Avatar
Looks Great Mikes!!
Think ima finally finish my drivers side in a couple weeks when i install my finished lights!!! can't wait!!!
Old Apr 10, 2009 | 10:14 AM
  #1140
ill Sedan
Thanks for the info and guidance Kurtis!
A few photos of the homies of TWC at HIN San Mateo
