S tech and H tech people lets see em!
Old May 17, 2009 | 12:14 PM
  #286
SuperStezzyG's Avatar
Originally Posted by myroncuz
whats the lowest offset i can go with my zstechs without rubbing? on 19x9.5 and 19x10.5? probably gonna run 245/35 275/35
20-22+ rear 275/35 set up you'll be ok. The front you can alot in your teeens
Old May 18, 2009 | 08:50 PM
  #287
myroncuz's Avatar
^^thanks, ive heard people doing +17 front and +18 rear.. i might go somewhere around there
Old May 22, 2009 | 03:40 AM
  #288
Gtrpnoyracer's Avatar
you know the Tein S techs right, on the rear i noticed that it doesnt drop that much and i wanted to lower it even with the front because the front lowers so nicely. I've heard about the whole spring mount mod but is there anything else possible to do like maybe cut just one coil off or so? lmk thanks
Old May 22, 2009 | 07:46 AM
  #289
Ralph0064's Avatar
do the spring mount mod. DO NOT by any means, start cutting coils.
Old May 22, 2009 | 05:28 PM
  #290
cturnbull802's Avatar
i am going to spring mod my passenger side front if i cant figure out why it is a little higher.
Old May 23, 2009 | 02:26 AM
  #291
viceversa's Avatar
^you can't do this mod on the front there are no spring mounts
Old May 23, 2009 | 09:21 AM
  #292
there is a rubber isolator, and the plastic on the bottom of the spring itself that can come out in the front.
Old Jun 1, 2009 | 08:22 AM
  #293
idrive_MD's Avatar
any chance anyone has a pair of front Z H-techs they want to get rid of? I have the Cobb Z-springs and I scrape everywhere. I have a front lip I want to install, but I dont think it would survive one day of normal driving. Shame though, I love the look:
Old Jun 9, 2009 | 10:28 PM
  #294
frozenmango's Avatar
can i run g s-techs without a rear camber and still align to spec? o
Old Jun 9, 2009 | 10:43 PM
  #295
RedSoxG35's Avatar
Here's a recent pic of my z stechs...just put these on last weekend. Love them so far!
<a href="http://s494.photobucket.com/albums/rr303/googlenerdy/?action=view&current=DSC01632.jpg" target="_blank"><img src="http://i494.photobucket.com/albums/rr303/googlenerdy/DSC01632.jpg" border="0" alt="Photobucket"></a>
Old Jun 9, 2009 | 11:18 PM
  #296
Asad_A203's Avatar
Quick question, I am going to be running Volk SF Winning with agressive offsets (19X9.5 +17, 19X10.5 +19) with a Kuruma Z front. The roads here are also crap. I know I have to roll my rear fender but am wondering if I can still keep my camber in spec (with a rear camber kit) and G35 S Tech Springs. Will I be rubbing with this combo with no ability to keep the camber in spec? Should I just do 350Z H techs (I am just undecided on the drop as some seem a bit lower even without the bumper stop mod and others look alot higher).
Old Jun 10, 2009 | 12:05 AM
  #297
nyckid's Avatar
You will be rubbing in the rear for sure. I am running 19x9.5 +17 (245/35/19) and 19x10.5 +18 (275/35/19) and mine rubs over small dips even driving slowly. I am lowered on g35 s-techs as well. Not sure about getting your camber back to spec. I need to get a rear camber kit soon and get an alignment and fenders rolled at at one time. But I'm pretty sure you can get your settings back to a reasonable setting. Not sure about getting it back to factory specs tho. Can someone chime in?
  #298
RaginRaj11's Avatar
Just installed the 350z h-techs. Ride feels great and the handling difference is noticeable.
Before:
After:
Old Jun 10, 2009 | 12:58 AM
  #299
Asad_A203's Avatar
Ah, thanks for letting me know. Do yo think it is because your fenders aren't rolled? I am getting mine rolled once I get my rims/tires mounted and think I will do 350Z H Springs with the bumper stop mod.
Old Jun 10, 2009 | 09:30 AM
  #300
can someone answer my question??
can i run g s-techs WITHOUT a rear camber kit and still get an alignment?
