S tech and H tech people lets see em!
Old Jun 22, 2009 | 03:09 PM
  #316
jlin615's Avatar
Originally Posted by LaConic2
any1 have uneven rears on g stechs? my pass rear is a little higher ? used set so they're settled
Yup, my passenger rear is higher by 1/4 inch or less.
jlin ur g is sex
Thanks!
Old Jun 25, 2009 | 02:16 AM
  #317
Yosef's Avatar
Mine is too for some reason, any way to get rid of this? for some reason mine still seem higher than other s-techs. Is it because mine are new? (it's almost been two weeks)
Old Jun 25, 2009 | 10:54 AM
  #318
frozenmango's Avatar
cut your spring mount duh
Old Jul 9, 2009 | 06:19 PM
  #319
g stechs 25mm spacers 245-35 front 255-40 rear
Old Jul 9, 2009 | 06:49 PM
  #320
jlin615's Avatar
^Looks great! Is your rear-right higher than rear-left?
Old Jul 9, 2009 | 07:04 PM
  #321
cturnbull802's Avatar
are the G s-tech lower than 350z h-tech?
Old Jul 9, 2009 | 07:05 PM
  #322
jlin615's Avatar
yes
Old Jul 9, 2009 | 07:15 PM
  #323
thanks! yea i actually had to roll the fends on my rear left. but its still not really that noticably uneven
Old Jul 16, 2009 | 12:30 PM
  #324
I Scare's Avatar
I currently have G S-tech on with F245/35/20 R275/30/20 and i rub occasionally on the passenger side front fender. When i drive another person (two including me), i tend to rub at like every bump. Making a turn will rub on uneven road. So would it matter if i switch from S-tech to H-tech? I am considering going back to stock height.
Old Jul 16, 2009 | 12:39 PM
  #325
jlin615's Avatar
Been there before when I was on H-tech, so I change the front tires from 245/35/20 to 245/30/20. I even switched to S-tech after that, still don't rub.
Old Jul 16, 2009 | 01:53 PM
  #326
I Scare's Avatar
What about your turns? even if you have a passenger? I think if i am by myself, i am okay. Just really hard with another passenger. I am just afraid that one day when i turn, it'll pull my fender. =X
Old Jul 16, 2009 | 02:04 PM
  #327
jlin615's Avatar
Never had a problem when turning.
Old Jul 17, 2009 | 03:08 AM
  #328
I Scare's Avatar
Is it bad to run H-tech in front and S-tech in the rear?
Old Jul 17, 2009 | 03:47 AM
  #329
Yosef's Avatar
Don't think so, I've heard of people doing that.
Old Aug 9, 2009 | 09:49 PM
  #330
drikx's Avatar
can i run oem 19s with 350z s tech without any problems? or would i need a camber kit/fender roll
