S tech and H tech people lets see em!
Old Feb 4, 2009 | 03:28 AM
  #166
phatice's Avatar
Originally Posted by 1992_eg
i know this tread is kinda old, but im getting z stechs on next week, im probably gonna do the rear spring mount mod maybe cut like 1/4. should i just wait until i get the rear camber kit? would i need a camber kit for the front? i've been researching alot about this.
i would just wait, cuz im running the z h-techs and it's pretty noticeable that the front tires are experiencing premature wear on the inner tire. The rears are sorta ok but i still get uneven tire wear. I would wait till the camber kits arrive before cutting the spring mount
Old Feb 4, 2009 | 09:54 AM
  #167
jlin615's Avatar
It really depends how much negative camber you want too. I have the Z h-tech with 0.5" springmount cut, negative camber at about -1.5 front and -2.0 rear, I can live with that for a good while.
Old Feb 4, 2009 | 10:08 AM
  #168
mt7rabbit's Avatar
+1 I would wait until you have everything in place before you start modding.
my pics
350Z-S-tech with .5" spring mod + rear camber adjustment.
Old Feb 4, 2009 | 01:36 PM
  #169
1992_eg's Avatar
yeah i just oredered the rear spc camber kit from ebay for 180, its not too bad and it looks easy to intall. but the front one goes for 400+ that one is gonna have to wait til next pay check. bills come firts lol
Old Feb 4, 2009 | 02:39 PM
  #170
g35TUNER-CHICk's Avatar
my pics
your G is hOt!!
...but man...
what size tires are you running in the back
Old Feb 4, 2009 | 02:52 PM
  #171
mt7rabbit's Avatar
thanks, I'm running 285/30/20 on the rear.
Old Feb 4, 2009 | 06:06 PM
  #172
irishsig's Avatar
Since this thread just got revived here's mine. Damn I need to get some new pics.
350Z htechs w/stock struts
20mm spacer F
25mm spacer R
Old Feb 11, 2009 | 09:21 PM
  #173
Pollock21's Avatar
Irishsig, did you need a camber kit? I'm planning on going with the g35 htechs, confirmed no camber kit needed front or rear. I wouldn't mind going lower with teh z htechs, but I'm worried about camber.
Old Feb 11, 2009 | 09:23 PM
  #174
str3ryderz's Avatar
looking good not bad at all for springs
Old Feb 15, 2009 | 12:49 PM
  #175
ZeRo G35's Avatar
Originally Posted by rh_334
s techs
What's your offset on those rims and did you have to roll the fenders with 19 inch tires on s-techs...
Also I assume if anyone goes with s-techs on stock struts they will need a camber kit?
I am trying to lower my car and just starting to do research on cost?
camber kit cost, install cost, s-tech spring cost...
Old Feb 15, 2009 | 04:28 PM
  #176
mubay's Avatar
my G s-tech on 20"
Old Feb 15, 2009 | 06:43 PM
  #177
SukaZenki's Avatar
G35 H-Tech w/ Spring Mount MOD
  #178
jlin615's Avatar
Originally Posted by mubay
my G s-tech on 20"
Looks nice! Did you mean S-tech for G35?
Old Feb 15, 2009 | 08:53 PM
  #179
rh_334's Avatar
yes you need a camber kit front and rear and i bought the kinetix kit for $700 from www.300zx.com + $50 for some SPC toe bolts +$150 for the S-techs +$150 for alignment and no i didnt have to roll my fenders because i am only running 275/35/19 i no a guy that has the same setup on 285s and he had to roll his but the total cost to lower it and do it right is $1050 if you do it yourself
Old Feb 15, 2009 | 09:36 PM
  #180
mubay's Avatar
Yes, G s-tech. Z s-tech drops the rear 0.2" more than g s-tech.
