S tech and H tech people lets see em!
Originally Posted by MIA BlazinVQ
no worries man.... but just wondering.... what the hell have you been doing the whole year you've been a member?
For whatever reason I guess I registered almost 2 years ago. Turns out, I'm getting a G. Coincidence or fate?
Originally Posted by premium plus
lol, it's funny actually. I found this board, looked around. Went to register, and it said "that username is already in use". So I just tried logging in, and it worked lol.
F A T E SON
Originally Posted by kingrukus
guys, are you using aftermarket struts with your lowering springs, particularly with the tien s-techs? i know when i owned a maxima, it was basically necessary to get aftermarket struts with lowering springs to ensure a quality/safe ride. how do the stock struts hold up with s-techs?
thanks
thanks
can anyone please answer me? i tried searching and couldn't find a direct answer. maybe i suck at searching...
Rear seems to 'bottom out' first when going over big dips at speed. But I think it inherent to the vehicle, since I've ridden in stock 350Zs that do the same thing.
Originally Posted by swapmeet
Intresting look with the 350z stocks.
Kinda has that OEM subtleness, but you still know..... something is different.
Well done.
Well done.
Originally Posted by tragedycat
How bad is it on the fronts if you don't have a front camber kit? I got an SPC rear kit and H-Techs that I haven't installed, but now I'm thinking maybe I should just go for S-Techs if the tire wear isn't that bad on the front...
thanks,
zee
