S tech and H tech people lets see em!
Are people running Z-htechs on their stock shocks and if so, how is that holding up? How many miles have you all driven?
I'm considering the modest drop that Z-htechs offer given my car is a daily, but if I need new shocks as well, I might just go straight to coils...
Unless you're POSITIVE that you will be completely satisfied with the amount of drop you'll get with your H-Techs, I'd recommend saving up for coilovers. I know I was only satisfied for a small amount of time before I wanted to go lower...
Before, on Z H-Techs:
After, on HKS Coilovers:
heres mine on 350z-HTechs + SPRINGMOUNT MOD (bought the spring mounts from someone else, I believe he said he cut .5 inch)
Not running any camber kits, stock shocks, and roughly 15k miles. No big issues, a bit of camber wear which can be canceled out by flipping tires..
These will be FS soon! (both springs and springmount) as I will be switching to coilovers within the next month or two!
hey guys, im debating to get either the h techs or s techs , z or g versions. im looking to get the best drop without needing a camber kit or need to replace my stock shocks. which version would you guys recommend? im running 245/45/18
^ I say 350z H-techs with the spring mount mod since you live in Brooklyn. Get a real good toe alignment and you may get away of not having a camber kit. You don't hear from too much people blowing out their stock shocks from running either of these teins,....i mean, you'll hear many recommendations, but not too many threads complaining of blown shocks. Don't quote me on that, I haven't really searched.
I need to do the same ASAP.
Tokico D-dpec DSP-9 shocks Tein G35 Htech springs
50deg_meet_35.jpg?t=1268538352
Mini_Meet_50.jpg?t=1268538488
UIC_trip_G35_3.jpg?t=1268538532
No you're not...I've gotta do the spring mount mod in the rear to level it out a lil bit. Its definitely lower in the back for sure but the front looks alot lower than the rear
