Old Nov 27, 2009 | 12:32 AM
  #6571
eurodre's Avatar
Originally Posted by tom's_Z
Just got in on the group buy for the DPE's. Going 9" front, 11 "rear......will I be able to fit 245 35 20" tires up front and the 275 30 20 in the back as a stretched setup??
uh no thats not a stretch at all, if u want stretch on a 9 and 11, you need a 215/35 on the 9 and a 255/35 on the 11 or even a 245/35 or replace 35 series with 30 if they rub
too much
also keep in mind that tires run small, true, and large so the stretch will be dependent upon that as well
and sorry only one of that blue passat that i cud find
Old Nov 27, 2009 | 12:59 AM
  #6572
Shrummi's Avatar
When my rims come in 20x9.5 and 20x10.5
225/35/20 and 245/35/20
or you think i should run smaller tires?
what do you guys think?
Old Nov 27, 2009 | 01:02 AM
  #6573
eurodre's Avatar
thats exactly what i have and i love them, now it depends on what tires you get that will further define the stretch
Old Nov 27, 2009 | 01:03 AM
  #6574
Shrummi's Avatar
i'm leaning towards generals thats what i bought for my gf's G mildly stretched and i love em.
Old Nov 27, 2009 | 01:06 AM
  #6575
eurodre's Avatar
here is a 245/35/20 on a 10.5 generals stretch
the front however didn't stretch as much as i thought it would so therefore i have more rubbing up front
that rear is more stretched than is shown in that pic, but there u go for refrence
Old Nov 27, 2009 | 01:08 AM
  #6576
Shrummi's Avatar
maybe i should run 215 and 235. or 30 series.
Old Nov 27, 2009 | 01:11 AM
  #6577
eurodre's Avatar
215/35 on a 9.5 is a pretty big stretch but yah go for it, u can also do ur fender work so that ur fronts wont rub
but yah up to u,
only reason i rub in the front is because i wanted poke in the front as well, so less fender work was done, but regardless on the freeway on dips ur tire will come close to the part were the fender and the front bumper meet, so u have to dremel down that metal piece as much as possible
Old Nov 27, 2009 | 03:30 AM
  #6578
geethreefeev's Avatar
i was doing some calculations, and went on works website. if i was to get a 10.5 in the rear with a -23 offset. that would be a 6 inch lip which is super massive, im going to be running on air, so what do you guys think? would a
20x10.5 -23 O disk be reasonable or is that to extreme?
Old Nov 27, 2009 | 10:41 AM
  #6579
Celestak's Avatar
^^ very doable with negative camber/ good fender roll and tire stretch. If you're on coilovers a revalve and stiffer springs will be a must if you want to ride slammed.
Old Nov 27, 2009 | 12:26 PM
  #6580
Frankieg35's Avatar
Omg -23 is sick do that!!
Old Nov 27, 2009 | 01:49 PM
  #6581
cturnbull802's Avatar
the 80s was all about positive camber
Old Nov 27, 2009 | 02:08 PM
  #6582
erklep's Avatar
^lol nice!
Old Nov 27, 2009 | 02:55 PM
  #6583
Royal_T's Avatar
You will have no prob with -23, since you are going to be on air you should be straight. Also if Yoshi can pull of -21 without air you should be goood
Old Nov 27, 2009 | 03:09 PM
  #6584
eurodre's Avatar
yah you can do it since ur on air, its easier
Old Nov 27, 2009 | 03:36 PM
  #6585
Frankieg35's Avatar
You guys on air can run some sick setups.. Lucky ****'s lol
