#812
on
Originally Posted by robzone
.....thats comment that needs some thinking behind it....Cost_A_G 's wheels reaquire alot of camber in order to run them, hence also the 225/255 35 set up, and his car is dropped as low as I am but he doesn't have the ground effects that give the car a more lower look "illusion", to most, his wheel specs are impractical along with his camber settings....on a side note...Cost_A_G's G is one of my favorite G's on this site
#813
#822
Originally Posted by ShanesG
do they make those wheels that will fit a G^^^
#824
#825
Originally Posted by Gr8One
I have so much negative camber. Its a pain. At high speeds I can hear the rear grinding against the rear inner wheel fender. I'll post pics later
Another thought which I have know idea if it exsist in the G35 world is using offset bushings. Looks like SPC's camber kit includes a rear lower arm and eccentric bolts/washers. You can actually get bushings with the eccentric bolt hole offset to one side instead of centered. This will alow you to press it in one way or the other to get more aggressive camber or less aggressive camber. My thought is using them in conjunction with the rear lower arm to basicly change the rear offset slightly so you can adjust the rear arm inwards and strighten everything out. Same thing I did on the miata!
SPC Camber Arm Setup
![](http://www.ccwheel.com/misc/dan/forums/g35/g35_camber.jpg)
Eccentric Standard Bushing
![](http://www.ccwheel.com/misc/dan/forums/g35/superpro_regular.jpg)
Eccentric Offset Bushing
![](http://www.ccwheel.com/misc/dan/forums/g35/superpro_offset.jpg)
