System Installed **PICS**
Old May 19, 2008 | 04:30 AM
Algy's Avatar
With the stock head unit, you got a high-low converter right? Does your subs only catch the lows? or the mid and highs?
Old May 19, 2008 | 07:12 AM
antonucci's Avatar
no high-low converter, the signal coming from the HU is low for the bose amp. just tapped into the rear right and left pre-amp outs
Old May 19, 2008 | 12:14 PM
young g's Avatar
Sweet, nice and clean, and stil have room.
Old May 19, 2008 | 03:37 PM
HaTa's Avatar
So fresh and so clean!
Old May 19, 2008 | 05:29 PM
shabarivas's Avatar
What! really? lol i got a LOC and I appreciate the additional tuning you get from having one.... matters if you care that much... I guess i do
Old May 19, 2008 | 08:47 PM
Algy's Avatar
So it only catches the low? How do i get my subs to catch the MIDS & HIGHS as well?
Old May 19, 2008 | 09:23 PM
antonucci's Avatar
the voltage from the output of the headunit is low, which is good because higher voltages cause distortion if you re-amplify them, which would have been the case if i tapped into signal after the amp.
to get your subs to catch the mids and highs (which i wouldn't recommend on subs) all you need to do is tune your amps low-pass filter to not cut off higher frequencys. check your speaker's frequency response and tune the low-pass filter no higher than the speaker can handle otherwise it will distort.
EnCr1pt3d
Jul 8, 2019 02:48 PM
RA102223
Aug 15, 2015 09:24 PM
Team STILLEN
Aug 10, 2015 08:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
lemmy999
Jul 25, 2015 12:13 PM
