Rear Strut Tower Bar Teaser
Old Apr 5, 2009 | 09:46 PM
  #421
xx7sephiroth7xx's Avatar
G
^ Hah. Several of the RareJDM team members have one, but we didn't think to ask one of them. Actually, I didn't even know that the iPhone had a Level App.
Old Apr 5, 2009 | 10:46 PM
  #422
psedog's Avatar
Back in SD**
Originally Posted by OCG35
My pics?... I didnt post pics
Mine isnt installed yet - still being plated
Fixed, my bad
Old Apr 6, 2009 | 12:28 AM
  #423
psedog's Avatar
Back in SD**
Sure does, I use iHandy Level. Free from the app store.
Old Apr 6, 2009 | 12:43 AM
  #424
G
Free? Wow. If only I had known...
Old Apr 12, 2009 | 05:26 AM
  #425
psedog's Avatar
Back in SD**
Originally Posted by RareJDM
This picture really threw me off. The sedan's mount is a bit different. I took out my side carpet and I couldn't find this mounting point. I then pulled out the mounts and I looked behind the forward carpet and found the holes. I'll post pictures in a minute.
Going to eat dinner then I'll post the pics.
Damnit, I just thought about my subwoofer boxes. They flow right where this is going to be. Looks like I'll be drilling holes through them and doing a little bit of fiberglass work... The price we pay, right
Luckily my boxes stop in the crevice just before this point. That was an area I debated back and forth about when I was creating my boxes. I'm lucky I stopped there
Old Apr 12, 2009 | 05:39 AM
  #426
dahkyne's Avatar
^ this mount is for a coupe...
Old Apr 12, 2009 | 06:21 AM
  #427
psedog's Avatar
Back in SD**
I know this, but there is no pictures posted for the Sedan....
Old Apr 12, 2009 | 06:35 AM
  #428
psedog's Avatar
Back in SD**
Alright, the bar is installed.
One of the holes on the car is bigger than the bolt. So it had a lot of wiggle room. So, I first installed the brackets snug, but not tightened down. Then when I got the bar in, I tightened up the bolts holding the bracket in.
I haven't taken the car out yet for a test drive. I'll do that in the morning on my way to work.
As you can see, it is level :P
My amp on the other hand isn't. Now I need to make a bracket for my cap. I have had it installed with Velcro for a while now. Mainly because I didn't want to put any holes in the carpet . Now all bets are off
Old Apr 12, 2009 | 09:58 AM
  #429
OH6 G35's Avatar
Excellent D.I.Y.!
Installed correctly and looks very NICE ! Great Job!
Each Mounting Bracket should be installed with the two Mounting Screws (Coupe towards the rear, Sedan towards the front), tightened just enough to hold the Bracket in place. Then, while pushing the Bracket up against the Inner Shock Tower Enclosure, tighten the two Bracket Mounting Screws. After tightening the Screws, a small "gap" may appear between the Bracket and the Inner Shock Tower Enclosure. This "gap" will disappear when adjusting the Bar. Adjust the Bar until Brackets become "snug" and no movement occurs.
CAUTION: DO "NOT" OVERTIGHTEN THE BAR!!
Lastly, tighten (snug) all remaining Hardware and your off!
Old Apr 12, 2009 | 10:44 AM
  #430
psedog's Avatar
Back in SD**
^^^ Why? What will happen?
Btw, thank you
Old Apr 12, 2009 | 10:50 AM
  #431
OH6 G35's Avatar
Potentially, the force applied (by the Bar) could "bend" the sheet metal, of the Inner Shock Tower Enclosure. We have yet to encounter this problem but it should be noted.
Old Apr 15, 2009 | 07:20 AM
  #432
psedog's Avatar
Back in SD**
Bumpage
Old Apr 15, 2009 | 01:53 PM
  #433
OCG35's Avatar
finally got my bar back today - bar and all hardware black chromed! Looks nice Brackets are poopy powder coat though, but it should all look good... Installing with SouthbayGSedan this weekend (hopefully) Every time I have an estimated timeline, something happens
Old Apr 15, 2009 | 01:59 PM
  #434
OCG35's Avatar
Originally Posted by ttrank
Mike, what did it cost to plate the bar?
$85 for just the bar (even though my ttl bill was quite a bit more than that - and I still have a few more pieces to do )
Old Apr 19, 2009 | 10:21 PM
  #435
OCG35's Avatar
Thumbs up I’m Finally A$$ Planted!
Rare JDM Sedan Rear Stabilizer Bar
Nice bar Zack (zackt69) & Dave (OH6 G35) ~ great quality! Thanks for the install help Darren (SouthbayGSedan)
I got the bar a few weeks ago in a hardy very much ready to ship box (plenty of packing material to protect)… it has taken a while to install because I wanted to black chrome plate the bar & hardware and powder coat the brackets a different color – it didn’t turn out quite as expected and some stuff had to be re-done – the bar looks a little chromier than when first received for some reason, it’s not quite a black as I’d like, but its decent – the pics below aren’t really indicative of what it looks like in person (especially the brackets) – but I’m not Marcus or Grant
~ anyway, that’s why it has taken so long to install.
As for performance… unfortunately I don’t drive the car much these days so it’s very hard to give fair evaluation of suspension stuff (I still don’t know how I feel about springs installed about 2 months ago because I’ve only driven the car twice since then)… but on my semi-spirited drive home from Darren’s; the rear end did seem very well planted. I didn’t push hard corners too much (yet) but it does feel tight and stable. Once I have a chance to try and swing the @ss around and get a real feel I’ll post better driving impression – but that might be a long time from now so I figured I’d at least give my prelim thoughts and post some pics.
If your car likes to shake it’s @ss like some hot chick at spring break this bar is not for you… but if you’re trying to rid the flex and squirrelly characteristics sometimes exhibited by the sedan – from what I can tell so far, this bar is a step in the right direction.
This post is also in the Suspension section
https://g35driver.com/forums/brakes-...ml#post4135619
and Sedan section
https://g35driver.com/forums/g35-sed...m-planted.html
