Rear Strut Tower Bar Teaser
Old Apr 19, 2009 | 10:57 PM
  #436
SouthBayGSedan's Avatar
Looks great Mike, glad I could be of some assistance.
BTW, do you have a 6-1.00 mm tap that I could chase the nut-plate threads with?
Old Apr 19, 2009 | 11:06 PM
  #437
CandlestickPark's Avatar
ill Sedan
Looks awesome Mike, the finish on the bar came out great.
Old Apr 19, 2009 | 11:08 PM
  #438
OCG35's Avatar
you know, I was tempted to write something else... but changed it
Old Apr 19, 2009 | 11:11 PM
  #439
OCG35's Avatar
thanks Marcus
Engine bay stuff is finally nearing completion... gonna be ready for pics soon (theres so much stuff in there that wont be realized by my crappy photo ability)
Old Apr 19, 2009 | 11:24 PM
  #440
ill Sedan
Originally Posted by OCG35
thanks Marcus
For sure Mike, let me know when you've got everything done.
Old Apr 19, 2009 | 11:43 PM
  #441
OH6 G35's Avatar
Great Work, Mike & Darren!
Mike...
The Bar and Brackets look "Awesome"!
The Black Chrome on the Bar and the Black Chrome Powder Coat really came out "fantastic"!!
The pictures don't do the finishes justice...In person...Wow! NICE!!
Old Apr 19, 2009 | 11:44 PM
  #442
OH6 G35's Avatar
...and Darren...I see you "lurking" as usual!!
Old Apr 20, 2009 | 01:41 AM
  #443
bikinilust's Avatar
I scrolled through this thread briefly to see if i could find an answer to my question, but havent been successfull
So here is goes:
Is the majority of the flex between the 2 towers in the center(vertically wise/where majority of the companies are placing the bar)? One would think that the majority of the movement would be between the tops of the 2 towers (higher than the usual RSB). Im thinking that everyone is placing the bars center because of the convience of the oem mounting brackets.
Please correct me if im wrong.
Also, someone mentioned the idea of having two bars for increased rigidity. So I thought id take that idea one step higher. How about two bars criss crossing, or a X bar? Either or the 2 with your adjustable ends, so that it can still be a "bolt on" item that'll fit anyones car. Wouldnt that rid the issue of any possible vertical movement?
Just a thought....
Old Apr 20, 2009 | 09:55 AM
  #444
OH6 G35's Avatar
We also assume that the "majority" of the flex would be at the upper most portion of the Shock Tower Enclosure. Placing a "horizontal" Bar in this location may be the "optimum" choice but when we first "proto-typed" our set-up location, we were very pleased with the results and have left the design where it currently resides. Too much stiffness may create a situation where the rear "breaks loose". A little flex is not a bad thing for a street car. Also, the vertical length of the Shock Tower Enclosure is "shorter" in the Coupes (as opposed to the Sedans), so I would imagine Coupes would have a slight advantage in performance.
Just a thought....
We pondered this idea, for a while, and decided (for the time being) that we would stay with this "current" configuration. The reason: we've "tested" this configuration, both on and off of the Track, and have been very pleased with the results. The back end of the vehicle tends to be more responsive, even with the single Bar. To "satisfy" the curious though, we may do the double set-up sometime in the future. The "X" configuration sounds interesting!
...thanks Mike!
Old Apr 20, 2009 | 04:46 PM
  #445
bikinilust's Avatar
Or if the X design isnt pleasing to the eye, but the concept is there... how about 2 "Y"s coming together @ the center. This way each side has 2 mounting points, but a single bar goes across the center....
kinda like this
and maybe to rid the pivoting points, one can have the extension portion of the bar dead center of the bar, instead of having the extension portion @ the ends.
kinda like this
for reference to understand my "mig-shift" drawing, heres a drawing of your current design
Old Apr 22, 2009 | 09:28 PM
  #446
psedog's Avatar
Back in SD**
That is Hawt!!!
I want mine black chromed now
If I do it. I'll leave the brackets alone, but I'll get the nuts painted black.
Isn't the current one more like this |-----|
Or a little more like /-----\
Originally Posted by OH6 G35
CAUTION: DO "NOT" OVERTIGHTEN THE BAR!!
I noticed that I have mine tightened down more than well everyone else. Should I worry?
Old Apr 22, 2009 | 10:00 PM
  #447
OCG35's Avatar
Originally Posted by psedog
That is Hawt!!!
I suggest powder coating or black chrome plating the nuts too... don’t paint them - no matter what you use as primer or adhesion promoter, they will chip when you put a wrench to them.
Your brackets will look good as is, good call on leaving them... mine were suppose to be a charcoal "crinkle black" powered coat which is textured like the side panels - the idea was to blend in so you don’t notice them... the color got botched... I thought about having it stripped and black chroming them - but I would have had to remove the Rare JDM plate and out of respect for the guys I didn’t want to do that (not paying attention to the fact that it wouldn’t be seen at all, even though Darren mentioned it to me) – I will probably eventually remove the brackets and have them done a different color (I’m **** about stuff like that – some people say I have OCD *ehem, Darren, Randy) – for the record, in person they don’t look like the pictures.
Anyway, your bar looks good as is too
Old Apr 22, 2009 | 10:46 PM
  #448
OH6 G35's Avatar
I would suggest that you reset your Bar.
1.) Loosen the Jam Nuts
2.) Turn the Bar until it's loose.
3.) Then reset the Bar by turning it until it becomes "snug"!
4.) Re-tighten the Jam Nuts.
You should be OK as is but, resetting the Bar is really easy!
Old Apr 28, 2009 | 08:09 PM
  #449
bigc's Avatar
Wings Nation
bump - buy more bars folks
Old Apr 28, 2009 | 08:32 PM
  #450
IvoryGT's Avatar
eh...i was put on a list...so where was I suppose to buy one?
