Spacers installed
Spacers installed
Got my 15mm spacers today and thru them on. 10mm in the rear. I have about 1/8" between the tires and the fenders in the rear. Fronts have about 3/16" of clearance. Not bad for running 255s and 285s.
BEFORE
AFTER
BEFORE
AFTER
Looks good. I just put some on too, 20mm in the back and 15mm in the front on my OEM 19's. I like your wheels too, I think the look is just right, flush but not sticking out flush look.
20mm would cause huge problems. I went with 15 and 10 becuz the tires are literally 3 credit cards thick away from touching the sheetmetal. The fronts rub hardcore but its on the fender liners, I may pull the front tires off and try to find and alleviate some of the noise.
BC coilovers
Hit me up if there are any meets coming up.
