RRYDE Custom Engine Bays
Old Mar 26, 2012 | 12:56 AM
  #466
856_reilly's Avatar
engine bay
Originally Posted by redpearl99
- paint your dip stick
- get an oil cap
- polish your a/c lines
- paint your vct solenoids
- move your Greddy catch can to the passenger side
- get a polished rad cooling plate
- get an Earl's Econ-o-fit clamp for your rad overflow hose
Thanks for the input. Where can I get a rad cover you are talking about? Also any suggestions on where to put the catch can? You know how we are working with so much room on these cars... Lol Thanks again
Old Mar 26, 2012 | 12:57 AM
  #467
alfhasg35's Avatar
There is a lot moar stuff to do other than FI..
i could easily spend another few g's in the bay before goin FI...
Old Mar 26, 2012 | 12:59 AM
  #468
CandlestickPark's Avatar
ill Sedan
^Yup...LOL
But going FI would be what I would do if you could swing it.
Old Mar 26, 2012 | 11:39 AM
  #469
Elmecano's Avatar
Originally Posted by bigc
if this is the area you're talking about (see attached pix), just take your time because its particularly rough. my process was sanding up from 400 -> 600 -> 1,000 -> 1,500 -> 2,000 grit sandpaper, then finishing up with jeweler's rouge and a dremel. that area is very tight and deep (giggity), so i wrapped the sandpaper around a 1/2" wide x 1/8" thick piece of wood so i could get in there with some force. btw, make sure you're wetsanding (a spray bottle of water is useful). don't just go sticking something in there dry and expect for things to go easy (giggity).
thanks for the tricks I am almost done (see picture before/after) it is not 100% perfect but I will deal with it.do you guy have or recomend to clear coat it??because last summer I have try to do it on my car without a clear and as soon as I drive when it rain it start to oxyde or water dry on it making spot.I have put like over 20hours to polish this one so I don't want to start over each time it rain.
I have lot of respect for RRYDE thats impressive work you do there!!
Attached Thumbnails RRYDE Custom Engine Bays-100_0002.jpg   RRYDE Custom Engine Bays-100_0014.jpg
Old Mar 26, 2012 | 11:49 AM
  #470
redpearl99's Avatar
it looks like you have it nice and smooth, but it still needs some finishing polish to give it a shine
looks good tho
I wouldn't clear coat it. the clear will haze to yellow after a while
Old Mar 26, 2012 | 12:01 PM
  #471
Elmecano's Avatar
looks good tho
thanks.....the picture is not good,it is shiny but if I put the flash on it will mess the picture even more lol
will it haze to yellow because of the heat??
Old Mar 26, 2012 | 12:31 PM
  #472
Sylvan lake V35's Avatar
^Yup...LOL
Quit buying $1000+ oil coolers and you could likely swing it
Old Mar 26, 2012 | 01:55 PM
  #473
Frankieg35's Avatar
I have one on my car but u can't have it!!
Old Mar 26, 2012 | 04:39 PM
  #474
bigc's Avatar
Wings Nation
lookin' good! as redpearl said, lay into it with some polish and you should be good to go.
Old Mar 27, 2012 | 01:24 AM
  #475
alfhasg35's Avatar
Props to you for trying to polish on your own.. Takes alot of time and ALOT of hard work..
I sanded down my VTC solenoids for about 4-6 hours.. not fun..
here is my timing cover before install..
obviously i didn't polish it myself..
Old Mar 27, 2012 | 01:26 AM
  #476
Frankieg35's Avatar
So nice!!
Old Mar 27, 2012 | 01:29 AM
  #477
TORETTO's Avatar
polishing my plenum myself right now. I hate how I need to hand sand everything past 220 grit. (i cant find hook face round sandpaper).
How did you guys sand those little nooks and crannys?
I'm also gonna try polishing the TB and timing cover. (bigc style, on the car) lol.
Old Mar 27, 2012 | 02:03 AM
  #478
BigVicG35's Avatar
I give you guys props for trying this on your own. I did maybe about a 2 inch section and gave up lol. I calling Sean aka SexySexy soon for mine.
Old Mar 27, 2012 | 02:08 AM
  #479
Lone Wolf's Avatar
You quitter lol
Old Mar 27, 2012 | 02:42 AM
  #480
redpearl99's Avatar
I will guarantee you will quit after the first day....the TC is 1000X more of a PITA compared to the plenum
