Interior lighting and led swap
Old Oct 10, 2012 | 06:13 PM
sLysKyv35's Avatar
Been wanting to post up my final results of me changing over the OEM AMBER to white/ blue for awhile now.
I know others have done this so I'm looking to compare to what over done.
Posted from G35driver.com App for Android
Old Oct 10, 2012 | 06:54 PM
.cakestar's Avatar
what? you changed leds or you want to see pics of people who have changed them? or both?
also you did not post any pictures... not sure if you intended to or not.
Old Oct 11, 2012 | 03:27 PM
sLysKyv35's Avatar
yes both....
I meant to post some pics let me try again...
Attached Thumbnails Interior lighting and led swap-1341816686305.jpg   Interior lighting and led swap-2012-05-13_21-13-38_420.jpg   Interior lighting and led swap-2012-05-13_21-14-52_517.jpg
Old Oct 11, 2012 | 10:22 PM
cv5boi's Avatar
Nice how much does something like this run?
Old Oct 12, 2012 | 04:03 AM
sLysKyv35's Avatar
Thanks was hoping someone liked it....
Well first of all I did all this myself. Found out it takes tons of patience and some trial and error to get ALL the parts the same color and to make it flow together.
First was the gauge cluster which I replaced with white 5smd led twist lock bulbs. Then I got blue transparent film with an adhesive backing for it to stick to the back of the faceplate. This allows you to define where the light will be blue and what light will be white. Another hard part was to get the odometer the same blue which I used a piece of blue transparent plastic and slide out the old one. Again this was the hardest part out of everything.
Second was the center climate control. I again used blue transparent plastic and placed it over the climate control lettering and then cut a piece of clear plastic in place of the orange tinted piece.
All together with leds blue film and blue plastic it cost around 100 give or take plus TIME. IF anyone wants for me to do this I could do it again but would take some time no longer than 2 weeks but it does take time and patience. Let me know and I could give you a better estimate on the price.
Old Oct 12, 2012 | 09:45 AM
htownimportz's Avatar
looks great, definitely would do this if i find an extra cluster, got a link for the actual bulbs you used? thanks in advance
Old Oct 12, 2012 | 02:12 PM
sLysKyv35's Avatar
Note...Again it takes more than just leds....
You must have leds (wide angle) SAND DOWN THE ORANGE THAT IS APPLIED ON THE BACK OF THE GAUGE FACE. AND THEN APPLY THE blue film to the back of the faceplate.
Otherwise if you just replace the bulbs it will STILL HAVE THE AMBER COLOR.
I WILL TRY TO GET MORE PICTURES THIS WEEKEND...
AND YES IT'S BETTER TO HAVE AN EXTRA GAUGE CLUSTER TO DO THIS.
Old Oct 13, 2012 | 02:06 PM
Michaelh90's Avatar
wow looks great.. u should of make a DIY.. i want to do this i hate the amber..
Old Jan 31, 2013 | 11:39 AM
Alexg35ya's Avatar
On the climate control you didn't swap any LEDs just the orange tinted glass and put transparent plastic film?
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
derres
Aug 28, 2015 03:27 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
Jadenkid22
Jul 14, 2015 12:33 AM
