Polished Plenum?
Old Apr 10, 2009 | 01:56 PM
HarrisonK's Avatar
Polished Plenum?
is there a DIY for a polished plenum?
Old Apr 10, 2009 | 02:07 PM
CandlestickPark's Avatar
ill Sedan
I'd highly recommend contacting SxExCx for one. His work top notch and it will save you a lot of time and effort.
Here are a couple of reads though if you want to try and tackle it yourself.
https://g35driver.com/forums/intake-...polishing.html
It is not like it takes a rocket scientist to do this, just more time and investment than is reasonable for most people. I recommend speaking to SxExCx about getting one.
Here is a nice DIY http://www.poleringsguide.se/english/
At a minimum you will need a kit like this http://caswellplating.com/buffs/alpolkit.htm
along with a grinder or electric corded drill, various sandpapers and final polishes. Probably close to $100 in equipment investment if you already have the power tools, then add in probably a whole day's worth of work (8-10 hrs)
Old Jan 5, 2012 | 07:25 PM
DaGdriver's Avatar
A polished plenum would look siick..
Old Jan 5, 2012 | 07:34 PM
redpearl99's Avatar
Listen to everyone else, poilshing is not as easy as it sounds it you'll end up spending more on parts, compound, tools..ect if you try to do it yourself
Contact SxExCx for great quality polished parts
Old Jan 5, 2012 | 08:19 PM
NATH_19's Avatar
Thread revival ?
Old Jan 5, 2012 | 08:25 PM
redpearl99's Avatar
holy, didnt even notice it was 3 yrs old
Old Jan 5, 2012 | 08:28 PM
DaGdriver's Avatar
Lol I didn't either. I was just bored and going through the threads.
Old Jan 5, 2012 | 08:30 PM
NATH_19's Avatar
Lol...
But sxexcex is still the best to get polished parts for our g.
But if your patient enough they keep popping used at the marketplace... For a lower price...
Old Jan 5, 2012 | 09:25 PM
DaGdriver's Avatar
Oh okay that's good to know, well I will focus on buying a polished plenum after I get the my compression rod bushings, fix the gas gauge problem our cars are known for, and get my valve cover leak fixed. Ughh that's what I get for buying a G with 100k on it.
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
