Reviews Reviews of specific modifications, posted by members
350zForums and the Pro-1 Engine Torque Damper
Old Jun 27, 2005 | 10:21 PM
  #31
amg35's Avatar
Florida G35 Club
shooter, can you post closeup pics of the engine mounting point? Have you figured out the adjustability of the damper? Have you noticed any benefit yet? I will install my damper this weekend. Thanks
Old Jun 28, 2005 | 09:50 PM
  #32
shooter's Avatar
It's not the critic......
amg35........i'll post those closeup pics for you tomorrow
i believe i have the damper adjusted correctly, but want to run the car for a few days and see if anything moves around......let you know more tomorrow.....
Old Jun 28, 2005 | 09:58 PM
  #33
amg35's Avatar
Florida G35 Club
Thanks, much appreciated.
Old Jun 29, 2005 | 09:43 PM
  #34
shooter's Avatar
amg35........
first pic
i attached the damper to the fender wall.....see the wire loom and the cable tie? pull the cable tie out of the pre-drilled hole in the fender wall and use a 7/16 inch drill bit and open that hole up.....that will allow just enough room to install the first screw...reach underneath the fender, above the front tire and you can thread the nut on.......you can see in the lower right hand side of the pic the damper is touching a screw head
second pic
shows the curved bracket installed on the engine and the adjustment of the damper.....install the damper, bracket and both provided screws before final tightening....this way you can adjust the curved bracket in the correct position.....the damper adjustment knurled nut is screwed all the way in towards the body and the eye screw is adjusted out away from the body as required.
third pic
assembled damper
fourth pic
i had to remove a small corner piece of the engine cover to make room for the curved bracket....i used a dremel...i lined it all up and marked the engine cover with a pen....it was very easy to cut the plastic
fifth pic
final install
i will continue to test the damper and adjustment......it is not hurting anything at the moment, so it will stay on for a while at least.....
Attached Thumbnails 350zForums and the Pro-1 Engine Torque Damper-dsc02573.jpg   350zForums and the Pro-1 Engine Torque Damper-dsc02577.jpg   350zForums and the Pro-1 Engine Torque Damper-dsc02579.jpg   350zForums and the Pro-1 Engine Torque Damper-dsc02580.jpg   350zForums and the Pro-1 Engine Torque Damper-dsc02567.jpg
Old Aug 28, 2005 | 08:37 PM
  #35
jnkirk1974's Avatar
Fastest G35 In Rockwall
How difficult would you consider this install? I'm considering the Stillen engine damper.
Old Aug 28, 2005 | 10:47 PM
  #36
shooter's Avatar
from what i have read the stillen is more difficult to install cause of the mounting location on the engine..........
the pro-1 is not bad at all......check the pics above
Old Aug 29, 2005 | 08:28 AM
  #37
jnkirk1974's Avatar
But, does the Pro-1 come with instructions?
Old Aug 29, 2005 | 11:12 PM
  #38
shooter's Avatar
no instructions..........just pictures of the final installation, you figure it out on your own
Old Sep 7, 2005 | 12:55 AM
  #39
TedRuxpin's Avatar
jnkirk- check with moog. He is a pro 1 dealer, and he lives in dallas.
Old Feb 21, 2011 | 02:26 PM
  #40
or_G's Avatar
Not really related, but do you guys know where I can buy another torque damper bracket elsewhere? I need a new bracket for my weapon R torque damper..
Freeman186
Sep 6, 2023 10:07 AM
magnetism80
Feb 1, 2019 10:00 AM
wuzz-upp
Oct 3, 2015 04:21 PM
Joe Gargano
Sep 18, 2015 11:17 AM
Jnm07
Sep 5, 2015 01:16 AM
